Close but No Cigar
In parallel with fiddling with actual old watch movements, I've been working through Mark's online watch repair course. To date I've worked through 21 lessons covering 97 topics. Although I "technically" passed my Level 3 course with a 76% score on the assessment (where the average is only a 78%) I didn't do well enough to receive a certificate as I did with Levels 1 and 2.
Luckily there's no time limit on access to the courseware so I plan to work through the 5 movements I have on hand and re-do the Level 3 FAULT FINDING course again. Truth be told, I knew once I got started that fault finding was going to be more difficult than either Level 1 or 2 and I was actually surprised that I got 76% on the assessment. I was also encouraged that the average grade was only a 78% which means that while I didn't do great - nobody else did either.
So, I guess the "achievement" here is that I'm only just beginning this journey and (possibly) that you can teach an old dog new tricks?
I don't know how long you have been working on Mark's courses. When I started my apprenticeship back in the early 70's it took me 5 years of learning then another 2 what they called improving so 7 years and even now being on this wonderful interesting forum I'm still learning I read something new nearly every day. grsnovi, you will never learn everything there is to know in horology. Keep at it just improving your skills will make you a better watchmaker.
Practice makes perfect.  I usually tell folks if you have problems assembling flatpack (IKEA) furniture then don't bother with watches. If you can dismantle/service/assemble stuff like car carburetors/brakes/engines then you're good to go.
Anilv
A subject doesn't exist were someone knows everything.  They is always something to learn on any topic.
7 minutes ago, oldhippy said:
I no nothing about cars and I don't buy flat backed furniture.
That might be that therory out of the window then. Haha. But I'm thinking that OH you have good taste in furniture and that you prefer to ride a pushbike .lol
Mostly yes i totally  agree with that. Unless your name is Godfrey as mine is. You can call me God for short . 😄
Yes G absolutely not possibly  you can. We should be realistic to a point to avoid disappointment.  But never underestimate what you can do. 👍
3 hours ago, Paul80 said:
Hope you weren't on a mission
No mission Paul. The first one was mostly things that I had absorbed while watching 3 dozen or so YT videos and was rather easy. I had started that mid-March while working on the first Elgin. I went through the material for Level 2 in April and wanted to do the fault finding one since all of the movements that I have to work on are non-runners (other than the Seagull ST36 that I purchased to work on for Level 2).
I think I learn better while doing.
grsnovi
Well done!
Like you I'm doing Marks course. As a complete novice I tried the Youtube watch and learn. However Mark's Course gives direction. Level 1 achievement was 90%. I'm mid-way though level 2. Never realised how much I did not know, and did wrong with regard to cleaning.
The forum is great help.
Really enjoying the training.
Regards to all.
Ross
    • Instead of using tweezers, put a piece of rodico onto a toothpick or pegwood. Then set your spring to the rodico, this way the spring is not under any tension when floating it back into the bloc. As you bump into the bloc when trying to find the entrance the rodico will give but still holds onto the spring ie. You wont have the rigidity of tweezers.
    • If frank says these bombè jewels are for balances and similar pivots then they are used cupped side facing the pivot and then capped i assume. In Nicklesilver's reply i guess that cup can also be reversed and used as an oil reservoir leaving the shoulder riding on a less frictioned domed surface. 🤷‍♂️ Hence the use of them on wheels closer to the escapement that have less torque requiring efforts to reduce friction and are also uncapped.
    • Looks that way, if it had any amount of significant jewel count it would say so on the dial.    Looks that way, if it had any amount of significant jewel count it would say so on the dial.  Same answer as Mike regarding the dial, its often just a slapped on name of a retailer but i thought you were way above this understanding Pete ?
    • Light naptha is what you need to be looking for. The carbon to hydrogen ratio is high with heavy naptha, it doesn't evaporate as well as light naptha and is prone to leaving more residue. Try tom's suggestion of the mirror test.
    • Its a big item Michael and a lot that could go wrong with the process of getting it to its new location. I once helped install one of these units into a conservatory that i had built. It was big and bloody heavy and took six of us to get it in safely. If you have sliding doors and you need to remove the whole frame then that may or may not go well. But i would advise getting a professional in if you have little knowledge on the installation of them. The glazing of the doors could well be 6mm laminated glass which again will be heavy very heavy if the glazing units are big. The glass would also need to be set up and packed correctly to open the doors properly more so if they are unframed and the sliders are upvc. Seems a shame but if no one is biting and that may be due to having no warranty i guess the only takers might be someone that installs them for a living and knows how to repair. If its fibreglass just be careful, i sometimes have to cut fibreglass baths out and they are nasty to work with . Thick gloves are definitely recommended,  not fun picking out fibreglass spells two days later that have started to go septic. Good luck with it all matey.
