Hello from Central Pennsylvania
JackF2
I often drive my the beautiful Lititz Watch Technicum campus and always find it fascinating that students there are getting a free education from Rolex on watch making. But I was even more amazed to (eventually) realize that I could learn rudimentary watch repair online. So here I am, having fun with teeny tiny parts that somehow fit together.
Welcome to the forum @JackF2
Free? Bugger it. I really live in the wrong country with respect to some things. Mind you, I think I would be far too old for Rolex to even consider. I will be learning by doing and hopefully do the BHI course somewhere down the track.
What are your interests? Watches, pocket watches, clocks? All of the above?
    • Is the Roamer not a split stem? I'm confused on your how your case is put together. If it is a front loader where is it you are putting the case screws? I love me some Roamer, do you have any photos?
    • Oh nice. I have a similar wedge style stump for my staking tool, so I'll give that a shot. Thanks!
    • Thank you all for the replies!  Very informative! True enough, the Gamsol took some time to evaporate and does leave a residue. So not all naphtha are created equal!  Need to find alternatives then. i was able to try Hexane recommended by Alex and it seems great.  I wonder what the cons are?
