Seiko 5606 and Omega 625
10 hours ago, suomaf said:
. I use my brass tweezers and screw drivers to fiddle with the movement.
Brass tweezers are a good choice i think for bigger parts they dont scratch so much as steel. Ive found steel better for smaller things such as screws and springs especially.  As the brass is too soft and to dress them down for smaller parts the tips become too weak.
unless it fits in the box. So I got a box of 12 places, and any watch that I pick up off ebay or other auction sites, I can fix and it must fit in the box then I am allowed to buy them.
Haha. Im very curious as to THE BOX. Its sounds ominous. Are the places in THE BOX of a special size ? So be careful about choosing the correct watch to fit in THE BOX or you will be buying a lot of watches for other people.
 She did not say anything about her watches fitting in the box.
Yes mate these women that live with us seem to have a whole different set of partnership rules, rules that we aren't made aware of until we break those rules 😉
8 hours ago, canthus said:
Found this on yt.  Interesting but seems a bit brutal at times, but by a professional. Interesting way of solving coning.
https://www.youtube.com/watch?v=egCwtMMoOCU
Amazing the way he untangled the entangled hairspring that was tangled to such an extent that the tangled hairspring that was so entangled eventually became untangled by the use of untangling tweezers that he used to take the tangle out of the tangled hairspring by untangling the hairspring that was so hopelessly entangled by tangles. Easy 🤷‍♂️
Say that fast 5 times 😂
Good news and bad news.
So I took the balance wheel out over the weekend and I could not really not tell if the hairspring was coned, I assumed that it was. I fiddled with the hair spring for about 45 mins and put it back into the balance cock. It lives! But bad news I am back to square one. No matter what I do with the hairspring stud, the beat error stays the same. It is almost as if adjusting the stud has no effect on the roller jewel at all. I am waiting on a couple of new balance complete with stud wheels from ebay to see if that will help. At least the watch is not dead, it is fast 4-5 mins a day, but not dead.
Can you show us a picture of the watch on whatever you using for timing machine so we can see what it looks like?
Then with no power on the watch in the balance wheel stopped look at one of the balance arms and moved the stud holder does the arm move?
Hey John,
I am saving up to get a proper Timegrapher, so for the moment I am using the watch accuracy app on Android phones. I know this is not the right way to do it and there is minimal information I can glance from this. Until I get the actual timegrapher, this is the way for me.
I have not had problems with it before, in that I could regulate watches using it to get to 0.1 or 0.2 ms beat error and +/- 1 seconds per day. However with this 5606A movement, It seems as if I did something to the balance wheel and specifically the stud holder arm. I know that the stud holder arm is supposed to allow us to adjust the position of the roller jewel, but now it seems that it does not do it. Would a coned hairspring or a bent hair spring make it such that the roller jewel will always be stuck at a wrong position?
I cannot get it to budge from 4.0ms. The wheel is also sticky, once it gets started, it will go until the power runs out but it needs help with a blower.
So I took the wheel off the balance cock again and took some photos.
26-05-2022-5053.jpgI suspect that the stud is not flat and off to an angle and now it seems also that the hairspring is slanted off to one side again.
Could this be the cause of me not being able to change the beat error?
Thanks!
Edited by suomaf
additional information
 The coil looks OK its has not coned as I first suspected,  unbend the hairspring near the stud to level the coil, best be done when balance is installed on mainplate so you can check its levelness after each tweak.
Thanks Joe,
I am guessing I am going to be doing this?
Any tips or hints?
Thanks!
Hey John,
Thanks!
Eyup matey. How you doin ?. A few things to discuss here. As Nucejoe says the coil seems to look ok on its own with no coning. You say it looks slanted but looking  at the photo this maybe because the weight of the stud is pulling one side down. I think you need to foget your app for the adjustment, for the time being and just try a visual check that the stud arm can alter the beat error. You should be noticing that the balance wheel is moving, watch the position of a spoke of the wheel change. Or better still if you can sight down between the center of the escape wheel and the banking pins the impulse jewel should follow through as a straight line when the beat error is getting close. This is easier done without the train wheels installed. It is also good practice on vintage movements where there is no adjustment arm and the beat error has to be done with adjustment of the collet. When the watch is in beat the watch should start up with minimal wind providing everything else is ok. When there is a certain amount of beat error the balance generally requires some encouragement to get going and depending on other factors will also not want to continue if the error is very poor. Try a visual mate first then you can go from there. Technology is not always what we want it to be, we should rely on ourselves as well to see what is going on. 👍
2 minutes ago, suomaf said:
Thanks Joe,
Any tips or hints?
Thanks!
No mate not yet. Make this a last resort when you ruled out everything else. HS manipulation is best to practise on something scrap first.
My amusement is always that newbies remove their balance wheels and show us pictures and ask what the problem is. Well first problem is easy the balance wheel out of the watch doesn't have a problem the problem is in the watch. So the first problem is the balance wheel has to go back into the watch because that is where I was looking for specific things that I can't see if the balance wheel is out of the watch.
Which is also why have the quote above you can't really tell how it's bent especially at the stud unless you're in the watch because the stud is heavy it typically is being pulled down it makes the hairspring look out of flat which it may or may not be. If you are checking the balance wheel for flatness out of the watch you would place it in a true in caliper where you can spin it and you can look at specific things which you would probably never see anyway so it's best to put it back in the watch where the problem is a problem
that I still need a picture looking straight down but in the absence of that it did give me a clue about something with the picture you have so that works out. You have a four Arm balance wheel and The roller jewel is on the other side someplace probably in alignment with one of the arms which is really good for you. Because when you put it back into the watch with no power you can push on your stockholder and the arm which is closest to the pallet fork pivots jewel should move back and forth to visually put this watch in alignment you just need the push the stud holder until the arm providing that's where the roller jewel is in alignment with over the pivot for the pallet fork and you will be in alignment in other words you will be in beat versus trying to use your Which is a waste of time.
Oh other problem with your Is your running insanely fast could be a regulation issue or probably they hairspring is touching something it's not supposed.
Unless you have somebody else learning watch repair since you're the person doing it that means you're the person who has to fix the problem. But first you have to figure out what the problem is before you can fix its. Then working on hairspring is is something you need to practice with so ideally you should have some practice sheep watches that you're not trying to fix where you can practice bending the hairspring and learning how to bend it back. Typically practicing on a watch that you're trying to repair when you have no experience at all well hopefully get a balance complete but that also is a problem on vintage Seiko watches so you need to practice some place first
Thank you John for your reply. I will have it back into the watch over the weekend and try to get the photos that you said.
@NeverenoughwatchesBeen doing ok, Thank you. Trying to sneak in some watch repair in the evenings after work. I will have the train off this weekend and put the balance and escape back on the plate. I think I understand that the visual check is what I need to do first.
Yeah I am dreading the HS stuff. I am waiting for the new old stock ones to arrive before I start with hair spring work.
 We have already seen a side view of the coil when in the watch, I am guessing its slanted because of a bend NEAR THE SRUD.
 Best to have just the balance and cock back on the mainplate without any other part, this will maximize your access to the coil and view of it as well as no other part is there to block your view or access.
 Do not toucn the coil, its perfectly alright. Its slanted and you spot where the coil is closest to the wheel, then go 180 degrees to do some unbending ,  so  the slanted side rise to level up with the rest of the coils. In case it get  even more slanted  when you  unbend, you know you should do the undending in opposit direction of what you did before.
I know   !!!     a vid showing this would be very useful.
I didn't see the guy in the vid show a case like what has happened to the coil in your watch or he did and I missed it.
Good luck pal.
  • 4 weeks later...
TLDR: Parts came, made some noob mistakes but got it up and running again. Thank you very much everyone.
So a few updates. I tried straighten out the hairspring and made things worse. The shape it eventually ended up was a what not to do list. It is good practice I guess for the next few that I will mess up.
I had been waiting for 2 balance wheel completes because I knew it was a high possibility that that is what I would eventually need. They came in these plastic thingys that I had not encountered before. I tried to open one of them, my fat fingers slipped and Balance wheel 2 in the bin.
Having been left with one, I tried to be very mindful of putting it back into the cock, and after much swearing and praying it seem to go back in fine. Putting the entire mechanism back on the empty plate gave me the ahhhh... moment, so that is how it is supposed to look and function.
With my package, I had also ordered a main spring coil, thinking since I am in here, might as swap that out. Color side facing out... the new spring went in fine, next the arbour and wouldn't you know it, the noob, me, had put it in upside down. Take it apart, pray, swear, and it was the right way up again.
Time for the full rebuild. Putting on the main plate was something that I would always struggle with, I think because of all the praying and probably swearing that I did with the main spring and the balance wheel, something got left over and the main plate went straight on all the needed pivots and it was good to go.
The rest of the rebuild went as well as expected. Screws and springs were launched into space and I am crawling on my knees trying to find them. I am now pretty much an expert at fashioning springs from guitar wires. and finally it lives!
I am waiting on the newly purchased timegrapher and stereo microscope to arrive so I can fall even deeper into the rabbit hole I dug for myself.
Thank you very much to everyone who helped me get this little sucker back up and running.
Yey suomaf mate i am so pleased for you. You should be very proud of yourself and your dogged determination to see it through to a successful end result, well done matey. All your trials and tribulations to get you there, you should consider as worthy lessons well earned, hell I'm proud of you. I very much look forward to our future conversations, i can see you are one to stick with us and this amazing interest for years to come. Speak soon matey 👍
Thanks buddy. I am waiting for the microscope to get here for the omega adventure. That thing is 1.75 cm 😂😅
40 minutes ago, suomaf said:
A few things arrived from Aliexpress and Taobao. I am just waiting on the spare 625 movement for me to practise and I am ready to tackle this next adventure.
Now then matey. Nice to see you back. You have your new microscope i see and also treating yourself to some other bits and bobs. Nice little set up you have coming along Suomaf good for you.
Cheers, my wife is giving me side eyes but we are still good at the moment. As long as it is not new watches. She does not know I got a few 1950s Chinese watches coming my way. All up the watches costs me in total around USD 60 😂 Good practice watches.
Haha sneaky. Come on though the wifes dont do too bad though do they. New clothes, new shoes, new handbags, new jewellery, make up, a nice car to drive, a nice house to live in. I think we deserve a little treat now and then. 🤷‍♂️ ( when we've been good boys ).
The best thing I did in my life was to trick her into marrying me 😂. She is in charge of our money so I cannot be the idiot that spends it all on the nearest distraction.
Could not resist had to play with the new toy a bit.
Edited by suomaf
grammar
On 5/10/2022 at 10:42 AM, suomaf said:
I found a pack of 5 on cousinsuk and got freaked out by the trustpilot reviews and backed off.
Wow, you're right about the reviews on TrustPilot. I'm utterly surprised. My experience with CousinsUK is 1st class. As long as you are aware that the conditions are those of business-to-business and not business-to-consumer, there really shouldn't be anything to be surprised or disappointed about.
EDIT: Cousins see themselves as a distributor. That is, you're really supposed to take your complaints to the manufacturer. Nevertheless, several times they have helped me out as a negotiator between me and the manufacturer. Really 1st class!
Edited by VWatchie
Haha. She sounds as though she has her head screwed on the right way round. You may not have tricked her, she probably just wants you to think that you did lol. She may just have worked out that you were the right one for her. 🙂
    • I've remained silent on this thread, and at the risk of upsetting everyone, the thing that worries me the most the the apparent absence of Mark. The moderators do a great job and the members also pitch in, and the site seems to run itself, but it is a concern for the future of this forum when the owner is absent for all intents and purposes. Like many of the comments above I would hate to log in one day and things be closed down as I rely on this site for ideas and knowledge and also cheer me up. maybe the Moderators could reach out to him, assuming he does not read this thread, and express our concerns and let us know the plans going forward? some kind of WRT ark
    • That was the exact reason for me starting this thread watchie. Still we haven't worked out how the regulars are going to hook up if it goes tits up. I honestly think something should be arranged to stay in contact, we all help each other so much.
    • Yeah ive watched that a few times before,  i couldnt find my old school dividers to scribe it up 😅 Yep thats the guy i bought a roll from . Thanks Nicklesilver that answers that perfectly and more or less what i thought an experiment over time would prove . The jumper arm is quite thick along its length, i left it that way intentionally, i thought the original was probably very thin, i didnt see that it was already missing. Setting isn't particularly stiff as such just positive, i still need to take it out and polish where it mates with the stem release.
    • Yes, "Sold out" is difficult to understand. There doesn't seem to be a lot going on. It's been nine months since any new video was published on the Watch Repair Channel. The Level 4 course on watchfix.com has been in progress for what feels like forever (several years!?). Maybe Mark's enterprises aren't doing well or perhaps already so profitable there's nothing much to motivate him for more material. Or, perhaps these days he's more into crochet. The real reason is probably something entirely different but it would be nice/interesting to know. I don't mean to sound gloomy or pessimistic, but I wouldn't be surprised to be met by an HTTP 404. Every day feels like a gift. Speaking of watchfix.com I've been postponing the "Level 5: Servicing Chronograph Watches" course for a very, very long time. Anyway, I just enrolled on it so it's going to be very interesting to see the videos. I must say, IMO there's nothing really that can compete with Mark's courses when it comes to presentation and video quality. It's simply world-class and makes me associate with some really expensive BBC productions.
    • Steel has some funny properties, or at least counterintuitive. The modulus of elasticity is effectively (not exactly, but close enough) the same for steel that is annealed and hardened. What changes is the point of plastic deformation* . If the movement of your spring doesn't pass that, it should work fine. It looks a little thick, I would thin it a bit maybe from the main body out about halfway, maybe 10-20% thinner (not in thickness, along its form). But if it works it works!   *So- if you have two bars of the same steel, one annealed, one at 600 Vickers (general hardness watch arbors might be), clamp them to a table so the same length is hanging out, and put a weight on the ends, they will bend the same amount. But if you continue to add weight, then remove it, at a point the annealed bar won't return to its original straightness. That's the point of plastic deformation. But up to that point, as springs, they are the same. However- their wear characteristics will be very very different. And getting the hardened bar past its point of plastic deformation takes a lot more effort.
