Replying
If you drag across and highlight a portion of somebody's reply you will then get the option to include that bit in your reply.
2 hours ago, NerfHerder said:
do I select "quote" to reply
As above.
If you just start typing in the space below the message you'll simply see what you replied.
2 hours ago, oldhippy said:
If you click on quote
As @oldhippymentions, you'll get everything from the person's answer and you can then cut out whatever you don't want.
    • Not SS but very slight wear on the underside edges have a little brass showing under magnification. New crystal arrived £3 with tax. Nice champaign dial color.
    • I also just realized I had that tech bulletin saved...but in French for some reason 🙂 No, I don't speak French. 2172_Bulova 11AOAC 11AOACD 11AOACB.pdf While parts are drying I'm on the hunt for a replacement crystal. I can measure the opening and get a generic one, but it'd be nice to find out what the original looked like first. Of course, case code 3093 does not appear in any of my reference materials. JulesBorel lists a C3093 case code, and shows Bulova part # 1222-5. Does anyone have information on this guy? I found a thread here talking about how the -5 is the height of the crystal, but that's as far as I've gotten. I also found one site that claims to have it in stock, but before I risk my $20 I'd like to confirm it's the right part.
    • Thanks for the replies. I did the job today and found that the oversized stem fitted just perfectly into the worn mainplate without any adjustment. Original stem diameter was 1.24mm and the oversized was 1.40mm. I did have to make an adjustment to the setting lever though. The small pip that engages with the groove in the stem hub was slightly to wide. I made that a bit smaller with a fine file. Don't ask me why that was too big, it just was. All working very well now. No wobble and not pulling out. New crown fitted as good measure.
    • Hi Vandan. Hi from a fellow newbie! Marshall has got a lot to answer for hasn't he! 😄. I also got hooked to this hobby after watching his videos.  Good luck with your journey to service your Grandfather's watch.   Nick
