My latest Mumbai Special Beauty
That FHF ST 96 movement looks familiar - There's one in my "Favre-Leuba Twin Power". They even had the cheek to engrave "Favre Leuba" on the movement. The dial feet had been cut off, and the dial glued on with loads of glue.
I believe that FHF sold the machinary for this movement to India (?), hence so many Frankenwatches.
Favre Leuba and Tissot seem favourites to have this movement fitted.
s-l1600.thumb.jpg.5a555322b7423d286ed20b39d1c50c69.jpg2.thumb.jpg.4986c92ed54f45038131f513f02b4fd3.jpg
Edited by mikepilk
    • I would go for the dearer spring. You won't need to remove the spring from the carrier ring and then use a mainspring winder to get it into the barrel, for a start. Also that spring is closer to the needed dimensions, especially the length. The length plays a part in the mainsprings strength. If you double the length you will half the force (strength) of the spring and vice-versa. A spring with 20 mm less length would be about 7% shorter, so technically would be 7% more strength, but I find halving this number is closer to real-world findings, so the spring would be about 3 to 4% more strength/force. On a mainspring that ideally kicks out 300 degrees of amplitude, a 3% increase in amplitude would be 309 degrees. Increasing or decreasing the length of the mainspring will affect the power reserve to a greater or lesser degree. It depends how much shorter or longer it is.
    • I recently bought this but not on ebay. I figured if I want something Japanese I better check Japanese auction sites since these don't seem to pop up on ebay. I paid 83 € plus shipping & taxes. I think it was pretty reasonable for a complete set in good condition.
    • Did you take the friction pinion off the large driving wheel and grease it? Although, now that I think about it, that shouldn't have any effect on the free running of the train if the friction pinion isn't interacting withe minute wheel/setting wheel...
    • I did in fact use Rodico to get the spring into general position and "hold" it there while I used a fine oiler to make subtle positional adjustments.
