Balance Holder Tool
HectorLooi
I bought this balance holder tool from AliExpress a couple of months ago. I thought that it would be handy for holding the balance while adjusting the hairspring collet to correct beat error.
But it turned out to be rubbish. The tack is so short that there isn't enough space to reach the collet.
I thought of shortening the height of the table but that would be quite a bit of work to execute it properly.
Then it hit me this morning.
 I simply extended the balance tack with a brass PCB standoff. It also solved the problem of a wobbly tack when the standoff is tightened.
6 minutes ago, watchweasol said:
Hi Hector  I saw these on the bay and wonered about them, as they support the balance whilst under inspection/repair and take the strain off the spring.  I thought the knurled post was adjustable in height but obiously not. I like your mod simple soloution to the problem
Hi ww. Hope you are well. Was just browsing the forum looking for relavent information. Can I ask your method of collet adjustment, I do have a way that seems to work well, although a little risky. I think I also have so e obscure tool that I think was used for collet adjustment but it seem to be more of a faff than anything
Edited by Neverenoughwatches
Hi NeverE  A good morning to you Sunny day in Scotland.  I used to use a screw driver to turn the collet. A menber had problens doing the same and I made him some tools to do the job , never got round to making myself some though.  They were made from the thin steel from wiper blades cut and shaped to slide in under the cock but you need to be careful.
Oh love Scotland especially  Edinburgh. My wife is part Scottish, and red haired,  which makes her double  quite the handful at times. But beautiful inside and out just the same. So would you do your adjustment on a tack or another way. I flip the cock on its back onto some rodico, then carefully lift the bal. wheel up and slide a driver in-between the hairspring.  I'm not keen on using a tack, I don't like the spring having to take the weight of the wheel for too long. What do you think
22 minutes ago, VWatchie said:
The safest and easiest way to adjust the collet I learned from the following post (2nd paragraph) by @nickelsilver.
Now then vw how you doin? That sounds similar to the way I use. I Like to stick the cock down to stop it moving around it's pretty quick that way to do. Did you see the tool I posted yesterday. # What is it #. Someone helped me I'd. It . I think it's a very old simple version  of that same tool nicklesilver has
That is the reason for having an adjustable table. It is raised to support the spring so that it doesn't dangle until it distorts.
In that same thread that @VWatchie mentioned, I showed the tool that I use on larger movements. For smaller movements, I just stick an old oiler in the collet and turn it.
Thanks Hector, mine doesn't  have the table and I really hate to see the balance wheel pulling down on the spring. I used to put a prop underneath to support it. But it was a bit of messing around so I've just resorted to flipping the cock over on its back and let the staff just sit in the top jewel. It just seems a safer method for me and a lot quicker.
Oh and I forgot to mention that my tack is a toothpick stuck in a piece of bluetack. This is the reality of my DIY watch repair make do tool world lol
Just out of curiosity ww. When you worked in Hull you said it was for East Yorkshire motors. Did you mean Yorkshire buses ?
Like nickelsilver described it. To make sure I'll quote the paragraphs I was referring to.
"For every day work, from the smallest ladies movements to marine chronometer, I set the balance with the cock on a bench block so the roller table is in a hole, balance on the block. Lift up the cock and move it over- not flipping it, just moving laterally, until I can see the slot in the hairspring collet, get in there and adjust (for tiny watches this is usually with an oiler, larger, a small screwdriver). Go back in the watch and check on the machine."
"I do the adjustment under the microscope, which is pretty essential as the adjustment is usually very very small. I hold a balance arm of the rim with tweezers while moving the collet."
~@nickelsilver
~@nickelsilver
I know I'm terrible at quoting paragraphs. I also reply to myself, I'm getting  there slowly, very slowly lol. Stop picking on me 😥, I'm not the only one that does it. And I also have a small phone and big fingers it's not my fault. Excuses excuses.
~@nickelsilver
Yup. That's exactly  how I do it. At least I'm doin somefing right then.
I quite like the look of that tool and may get one to modify.
I’m still surprised at the number of people who are paranoid about deforming hairsprings by suspending the balance wheel by the spring. In my experience, there are few balances which are heavy enough to cause damage if you handle them carefully.
Hi Rodabod. My reasoning was from dealing with an old oris. The spring was an old carbon very fatigued spring that really stretched under the weight of the wheel. Really needed replacing bit I was trying to keep as original  as possible.
No worries! The only reason I cited manually is that sometimes the links don't seem to work, or confuse, at least myself 😆
    • Never and others. Yes like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
    • Get someone local to tig it ,very easy fix and should only take a few minutes so probably wouldn’t cost much ,or failing that get it very clean and silver solder it. Dell
    • Hi, The winding pin is not split, well that's how it was when I obtained the watch. The movement is front-loaded and here's a picture of where the case screws are fitted. The face picture is before I dismantled it.
    • I dont think mine is. Its an idea to have them all in one place if possible, then a quick screenshot will have them saved. Unless anyone has any other ideas of how to reconnect
    • My email address is in my profile, feel free all to drop me a quick hello.
