Carriage Clock Bodge's Fixed + Service
clockboy
Well a follow on from my post yesterday regarding a bodged hands. You sometimes just get that gut feeling that all is not well especially when a watch/clock repairer had returned it with "to knackered to fix".
I had added some pics of the service & poor workmanship I put right. The hand issue is on my previous post.
The minute wheel is attached to most carriage  clocks with a screw/post. When I opened the case the wheel was at an acute angle. It was fitted with this. The shaft that supports the wheel was very loose the screw/post was bent at the tip the head was also bent & whoever made this one had calculated the length incorrectly so made it fit with a brass bushing.Also the thread had been stripped on the screw & also on the case plate.
So I had to make another. I also had to re-tap the plate. Sorry guys but did not take pics while making the part also some of the pics are out of focus but here are a few after making the screw/post. I tapped the case with a 1.4mm thread which was worry because I only had a cheap die so very very gently when cutting the thread.
Drilling
Tapping
Cutting screw head slot
Finished Part
Testing all fits & runs smooth
Some pics of polishing & burnishing the pivots
Job done> The job is not perfect the balance wheel is kinked but to risky to fix. It has been up and running for the last hour keeping good time .
I have made a small vid
    • Before putting it back in the case I would fit the hands and use a pin vice on the stem to make sure the hands were in line.
