Uploading Images To The Forum
You can add images to your post simply by using the "Click to choose files" link which you will find below the post editing box. If you do not see the link then use the "Drag files here to attach, or choose files" function which is found at the bottom of each edit box. You will also find a drop down menu to the right of the editing box "Insert Other Media". From here you can use an attachment you have previously uploaded in another post, or you can insert an image from a URL on another website or file sharing facility.
Once you have added the files they will upload and you will see a "+" symbol next to each uploaded image. Click this and the image will be placed at your cursor position in the editing window.
Please make sure you compress your images using simple software so that you do not exceed this limit and also it will allow people to view your pictures much faster.
If you have a lot of images I recommend you using a bulk photo compressing software like Faststone Photo Resizer.
  • Mark unlocked and unpinned this topic
  • Mark pinned this topic
If you are uploading from your phone using Tapatalk then you don't need to resize.
But if you are uploading using a regular web browser you will need to make sure the images are a reasonably small file size first. Using photoshop or faststone resized I can usually compress a 4mb image down to well under 100k
  • 6 months later...
I had an issue where it appeared the gallery upload was just hanging (I was being patient!) and as a result I seem to have managed to upload multiple images to: http://www.watchrepairtalk.com/gallery/album/22-non-working-mst-522-into-a-watch/
I can't however find a way to edit the gallery to remove the duplicates! Can you advise please.
Many thanks.
    • OK, welcome in the world of alarm clocks... I guess the 4th wheel is dished because it is from another movement. If it was not dishet, then it would not mesh with the pinion of the escape wheel, am I right? The marks of wear on the 4th wheel pinion doesn't corespond to the 3th wheel table position, at list this is what i see on the picts. Calculating the rate is easy - there is a formula - BR = T2 x T3 x T4 x T5 x 2 /(P3 x P4 x P5) where T2 - T5 are the counts of the teeth of the wheels tables, and P3 - P5 are the counts of the pinion leaves. Vibrating the balance is easy - grasp for the hairspring where it should stay in the regulator with tweasers, let the balance hang on the hairspring while the downside staff tip rests on glass surface. Then make the balance oscillate and use timer to measure the time for let say 50 oscillations, or count the oscillations for let say 30 seconds. You must do the free oscillations test to check the balance staff tips and the cone cup bearings for wear. This kind of staffs wear and need resharpening to restore the normal function of the balance.
    • Glue a nut to the barrel lid, insert a bolt, pull, disolve the glue.  Maybe someone will have a better answer.
    • The stress is the force (on the spring) x distance. The maximum stress is at the bottom, and decreases up the arm. That's why they always break at the bottom. I used a round file, then something like 2000 grit to finish. I gave the rest of the arm a quick polish - no need for a perfect finish. Just make sure there are no 'notches' left from cutting/filing. The notches act like the perforations in your toilet paper 🤣
    • It's probably a cardinal rule for watch repair to never get distracted while at the bench. Yesterday, after finishing a tricky mainspring winding/barrel insertion (I didn't have a winder and arbor that fit very well) I mentally shifted down a gear once that hurdle was passed. There were other things going on in the room as I put the barrel and cover into the barrel closer and pressed to get that satisfying snap. But when I took it out I realized I never placed the arbor.  When opening a barrel, we are relying on the arbor to transfer a concentrically-distributed force right where it is needed at the internal center of the lid. However, when that isn't present it's difficult to apply pressure or get leverage considering the recessed position of the lid, the small holes in the barrel and the presence of the mainspring coils. It was a beat-up practice movement so I didn't take a lot of time to think it over and I pushed it out using a short right-angle dental probe placed in from the bottom, but that did leave a bit of a scratch and crease in the thin lid. I had also thought about pulling it using a course-threaded screw with a minor thread diameter smaller than the lid hole and a major diameter larger, but that may have done some damage as well.  Thinking about how this might have been handled had it been a more valuable movement, is there a method using watchmaking or other tools that should extract the lid with the least damage?
    • 🤔 what happens if lubrication is placed directly on top of epilame ? Making a small groove so the lubrication doesn't spread across the component but what if when lubing a little overspills and sits on the epilame .
