Uploading Images To The Forum
You can add images to your post simply by using the "Click to choose files" link which you will find below the post editing box. If you do not see the link then use the "Drag files here to attach, or choose files" function which is found at the bottom of each edit box. You will also find a drop down menu to the right of the editing box "Insert Other Media". From here you can use an attachment you have previously uploaded in another post, or you can insert an image from a URL on another website or file sharing facility.
Once you have added the files they will upload and you will see a "+" symbol next to each uploaded image. Click this and the image will be placed at your cursor position in the editing window.
Please make sure you compress your images using simple software so that you do not exceed this limit and also it will allow people to view your pictures much faster.
If you have a lot of images I recommend you using a bulk photo compressing software like Faststone Photo Resizer.
  • Mark unlocked and unpinned this topic
  • Mark pinned this topic
If you are uploading from your phone using Tapatalk then you don't need to resize.
But if you are uploading using a regular web browser you will need to make sure the images are a reasonably small file size first. Using photoshop or faststone resized I can usually compress a 4mb image down to well under 100k
  • 6 months later...
I had an issue where it appeared the gallery upload was just hanging (I was being patient!) and as a result I seem to have managed to upload multiple images to: http://www.watchrepairtalk.com/gallery/album/22-non-working-mst-522-into-a-watch/
I can't however find a way to edit the gallery to remove the duplicates! Can you advise please.
Many thanks.
    • people be honest.... Swatch is evil for the watchmakers and repairers, BUT not everything in watches from Switzerland is from the Swatch-Group. As far as i know, Selitta got sacked by Swatch as a Movement-Assembler for them and they started to produce Movements in their own Name with slight Modifications. As far as i know, they sell Parts to the Market for their Movements. In most cases, if a ETA-Movement fails, it is a valid Option to replace it with a Selitta Movement, which i consider the Solution for this Mess with the Swatch-Group...... I have no Connection to anybody at Selitta, but being a Swiss-Guy, i still like to have Swiss-Made Watches, but not from the Swatch-Group.   ok ? regards, Ernst
    • Just one more greedy act by Swatch. They started a number of years ago here in the US..cutting off supplies to watchmakers that could build complications that many Swatch houses couldn't even touch. Old school masters who had gone through some of the most prestigious houses in the world. Otto Frei has some statements on their page about it. I tell all my customers to avoid new Swiss watches like the plague,..unless they just want an older one in their collection that still has some parts out on the market, or they have really deep pockets and don't mind waiting months and paying through the nose to get it back. Plenty of others to choose from..IE Seiko,..or other non-swiss brands Even a number of Chinese brands are catching up with the Swiss,..and I think that in time, their actions will be their downfall
    • Yes. If that's not what you are experiencing...start looking for something rubbing. A 1st guess is that one of the hands is rubbing against the hole in the center of the dial. Especially if you now have lower amplitude in face up/ face down positions.
    • Once a movement has the dial and hands put back and it is recased, would you expect the assembled watch to have the same amplitude as when the movement is in a movement holder and is without hands and dial? Thanks
    • C07641+ not sure what the "+" is for after the last digit.
