Hello From St Louis Mo Usa
My name is Aaron, and since purchasing my first "nice watch" a couple of years ago, I've become obsessed with how mechanical watches work. I've managed to repair a few with minor damage, and destroy a few more struggling to learn. Luckily, nothing very valuable. My latest success was getting this guy running, which had some water damage that ceased up the auto-winding and train.
After finding this place on YouTube, and eading through some of the posts, this looks like a good community with a wealth of knowledge. Thank you for letting me be a part of it.
Aaron
post-1009-0-95875300-1431747369_thumb.jp
Hello Aaron and welcome,
We don't have a "Stargate archy thing" in the North East UK but we do have a ruddy great big Angel !
Look forward to your postings.
Cheers,
Vic
    • I would go for the dearer spring. You won't need to remove the spring from the carrier ring and then use a mainspring winder to get it into the barrel, for a start. Also that spring is closer to the needed dimensions, especially the length. The length plays a part in the mainsprings strength. If you double the length you will half the force (strength) of the spring and vice-versa. A spring with 20 mm less length would be about 7% shorter, so technically would be 7% more strength, but I find halving this number is closer to real-world findings, so the spring would be about 3 to 4% more strength/force. On a mainspring that ideally kicks out 300 degrees of amplitude, a 3% increase in amplitude would be 309 degrees. Increasing or decreasing the length of the mainspring will affect the power reserve to a greater or lesser degree. It depends how much shorter or longer it is.
    • I recently bought this but not on ebay. I figured if I want something Japanese I better check Japanese auction sites since these don't seem to pop up on ebay. I paid 83 € plus shipping & taxes. I think it was pretty reasonable for a complete set in good condition.
    • Did you take the friction pinion off the large driving wheel and grease it? Although, now that I think about it, that shouldn't have any effect on the free running of the train if the friction pinion isn't interacting withe minute wheel/setting wheel...
    • I did in fact use Rodico to get the spring into general position and "hold" it there while I used a fine oiler to make subtle positional adjustments.
