Is It Ok To Re-Model A Movement
I have a Mido D9i7, that has had a mishap and lost one of the pinions. I have tried everywhere and also bidded upto £40 for a movement for spares. Didn't get it....... :(
Is it ethical, to make a new part to lower the jewel hole, in the bridge, to get the watch going in a condition not as the original?
Hi Keith, are you intending to turn a new pinion on the original shaft then make a new jewel setting that will sit lower to match the shortened pinion? A couple of really tricky operations!
On the subject of ethics, if it's your watch do what makes you happy. The only thing is if you sold it, you should really tell the buyer that the movement has been modified.
Personally I think that's ingenious and par for the course when repairing old watches! If you can't find or make a new part adapting what you have is the next best thing. Be interesting to see how you achieve this.
Hi, this was my method. Be it right or wrong, it worked. Took absolutely ages. Just to lower a jewel 0.3mm. Jeez
Top pivot totally gone. Tried everywhere for one ..... even India, Philipines etc.
This is the Jewel I am going to install......
Had to make a hole to take the new bush to allow reaming as the bush is 1.9 mm...... this is an old Gash plate
Let the reaming begin............
Jewel in new bush....
Inserting Jewel into Bush
Removing Bush from Plate
Jewel in Bush
Now the Bridge...... Preparing to Ream....
Used reamers in steps of 0.1mm to increase aperture for Bush.....
Bridge & Jewel in Bush.......
Insert Bush into Bridge.......
Bush in Bridge.......
Phew, all done and back on watch............
Laborious, but saves another watch. Overall, the finished works look no worse than the patina on the watch already
  • Like 6
Very, very well done. :)
Just yesterday, I had to reduce the seating level in an old no name movement to take a donor end stone setting. It had to be done and another watch is saved from watch heaven.
If nothing else is available, it's perfectly acceptable to make modifications to enhance/save a watch - that is the nature of the job, and what keeps the job interesting to be fair.
Thank you Mark. Your praise goes a long way ............... :)
    • Yeah ive watched that a few times before,  i couldnt find my old school dividers to scribe it up 😅 Yep thats the guy i bought a roll from . Thanks Nicklesilver that answers that perfectly and more or less what i thought an experiment over time would prove . The jumper arm is quite thick along its length, i left it that way intentionally, i thought the original was probably very thin, i didnt see that it was already missing. Setting isn't particularly stiff as such just positive, i still need to take it out and polish where it mates with the stem release.
    • Yes, "Sold out" is difficult to understand. There doesn't seem to be a lot going on. It's been nine months since any new video was published on the Watch Repair Channel. The Level 4 course on watchfix.com has been in progress for what feels like forever (several years!?). Maybe Mark's enterprises aren't doing well or perhaps already so profitable there's nothing much to motivate him for more material. Or, perhaps these days he's more into crochet. The real reason is probably something entirely different but it would be nice/interesting to know. I don't mean to sound gloomy or pessimistic, but I wouldn't be surprised to be met by an HTTP 404. Every day feels like a gift. Speaking of watchfix.com I've been postponing the "Level 5: Servicing Chronograph Watches" course for a very, very long time. Anyway, I just enrolled on it so it's going to be very interesting to see the videos. I must say, IMO there's nothing really that can compete with Mark's courses when it comes to presentation and video quality. It's simply world-class and makes me associate with some really expensive BBC productions.
    • Steel has some funny properties, or at least counterintuitive. The modulus of elasticity is effectively (not exactly, but close enough) the same for steel that is annealed and hardened. What changes is the point of plastic deformation* . If the movement of your spring doesn't pass that, it should work fine. It looks a little thick, I would thin it a bit maybe from the main body out about halfway, maybe 10-20% thinner (not in thickness, along its form). But if it works it works!   *So- if you have two bars of the same steel, one annealed, one at 600 Vickers (general hardness watch arbors might be), clamp them to a table so the same length is hanging out, and put a weight on the ends, they will bend the same amount. But if you continue to add weight, then remove it, at a point the annealed bar won't return to its original straightness. That's the point of plastic deformation. But up to that point, as springs, they are the same. However- their wear characteristics will be very very different. And getting the hardened bar past its point of plastic deformation takes a lot more effort.
    • @JohnR725 now that you've mentioned it. This is actually the second aftermarket spring (same place and brand) I ordered as the first one broke. The eye on which the arbor pulls on, broke off on the first spring after the first wind, and also it was a bit to large for the arbor. Looked like on one the second picture in the 2nd group. The second one was exactly the same, I had to bend it a bit, to give it a more prominent curve to the end of the spring so that the arbor catches the eye.  Also I believe both were 5-10mm shorter. Not that I writing that, I feel a bit dumb, as the spring might actually been the problem all along, although its advertised as a substitute to the original...
    • The CS70 is the only one they show as annealed.  A further search on ebay, I found CS75 and CS100 annealed carbon steel strips  e.g. https://www.ebay.co.uk/itm/314072784422
