Cousins sell an antistatic bench mat with the label A*F Switzerland. It consists of two layers the upper green and lower white. Between the two is a space that in the sample that I purchased contained some air. If it was made in Switzerland there would be less of a problem, but it was probably made at sea level, perhaps the South China Sea? At our altitude of 720 m it inflated like a flat balloon. The solution was simple, just a hole in the lower white skin. Anyone tempted to buy this 'Swiss' version and living at high altitude, for example Denver, should note this fix. Or try the cheaper Cousins model.
  • 4 weeks later...
I've struggled with this one, the cousins self adhesive ones are hit and miss, sometimes they're okay, but I've effectively had to replace one as soon as it arrived once, the bergeon self adhesive ones are probably one of the the best, but I just can't justify spending that much on a plastic mat. (I mean it really is insanity) The AF Swiss ones, you can't get these as self adhesive, so these have a padding underneath that grips the work bench, but they are a nightmare because they're made poorly (believe it or not) because it's quite literally impossible to get them to sit flat.
Edited by Ishima
You can always go really cheap, a sheet of A3 or A4 paper and replace it every job. The small raised table that sits on top of my workbench was designed to take a sheet of A4 and has worked well for years. White works fine. The only reason I have Bergeon mat fitted on it just now is that I was given it.
Same here. Sheet of paper at first, light green Bergeon mat now.
  • 4 weeks later...
  • 7 months later...
I used to yearn for a black bench mat with side walls but no one makes those anymore. I have been using a cheap mat  but it is too hard and things that bounce and hide do a great job on this mat. I was thinking about the Bergeon 7808 in classic green but now I see so many variations including ridged mats. I don't want an adhesive back since I move from my real bench to the computer bench quite often.
Recommendations?
I recently picked up two of these;
https://www.amazon.com/dp/B011R32JKM/ref=cm_sw_r_awd_H2XUwb3HPC3SH
They are sold as a hi temp silicone baking mat but work quite well as a bench mat. Parts are easy to see and don't roll or bounce away easily. They are available in various sizes and colors for reasonable money. Seem to wipe clean without much trouble, and can be rolled up for storage when not in use. I am very happy with how it has worked for me, but maybe I just don't know any better since I never had a purpose-made bench mat for watch repair.
Edited by steve855
picked up two of these...
I suppose you can always use double sided tape to affix it to the bench/table if it is not staying properly in place...the price can't be beat if it performs well. The different versions from Horotec, Bergeon and Chinese range between US$12 and US$45, the cheaper are either non anti skip or peel the back for permanent (glue) attachment...color will also make the price vary.
    • I have it, so until we get a lunch one day , nearly everyday is with my mum at the moment.
    • In the meantime whilst awaiting a better plan, please drop me a quick hello on my email.
    • I looked at it like this, I've built a lot of stuff in my time, building structures and furniture,those are my creations and they will still be here way way after I'm gone. Traditional watchmakers felt the need to pass their knowledge on, ideas that they created . I assume with them as it is with me, leaving their mark on the earth, a way of being remembered. This creation of Mark's has brought thousands of people together to pass their knowledge around,  ideas that will continue to be used for lifetimes. Ideas that should continue to be procured. If for whatever reason the forum ceased to exist, not quite like Ranfft's, that didn't disappear but much less usable. Then that is sad, such a massive loss of communication between good people and a wealth of knowledge lost. There should be something in place for when that happens which could be next week, next year or in 10 years. Might not be a topical subject for a lot of folk or boardering on controversy, i did say i talk about stuff other people dont. But if you dont talk about it and something happens then you've lost it and you ain't gonna fix it .
    • I've remained silent on this thread, and at the risk of upsetting everyone, the thing that worries me the most the the apparent absence of Mark. The moderators do a great job and the members also pitch in, and the site seems to run itself, but it is a concern for the future of this forum when the owner is absent for all intents and purposes. Like many of the comments above I would hate to log in one day and things be closed down as I rely on this site for ideas and knowledge and also cheer me up. maybe the Moderators could reach out to him, assuming he does not read this thread, and express our concerns and let us know the plans going forward? some kind of WRT ark
    • That was the exact reason for me starting this thread watchie. Still we haven't worked out how the regulars are going to hook up if it goes tits up. I honestly think something should be arranged to stay in contact, we all help each other so much.
