Golf scorer
I have just serviced this Swiss made golf scorer. The main interest to a watchman is that the reset of the scores is done by turning the crown a full circle and each score is reset by the 'hammer' labelled A in exactly the same way as the second and minute hand flyback resets of a chronograph.
  • Like 6
  • 4 weeks later...
On 1/18/2022 at 3:07 AM, JCB776 said:
Hi Jack,
I have the same one, how much would you estimate a servicing is and are you located in the United States? Regards
I had this in my workshop to fit a new glass and to clean out accumulated dirt. I cannot estimate time needed to fully service. A guestimate would be two days assuming no need for parts. And no, I am on the other side of the pond. All the best.
    • An update, for everyone who contributed advice, and for those who come after with a similar problem. Based on the answers received, I decided to work on the face of the hammer first. I used a square degussit stone to guarantee a vertical surface to work against, and ground the face back until it was square across 90% of the depth. I was conscious of the risk of removing too much material.* After I'd got the shape how I wanted it, I polished the surface with lapping film. To cut a long story short, it did the trick and the hammer hasn't slipped off the cam since. Of course, that wasn't the end of my problems. Have a look at this video and tell me what you think is wrong. https://youtu.be/sgAUMIPaw98 The first four attempts show (0 to 34 sec.) the chrono seconds hand jumping forwards, the next two attempts (35 to 47 sec.) seem "normal", then on the seventh attempt (48 to 54 sec.) the seconds hand jumps to 5 sec. and the minute counter jumps to 1. The rest of the video just shows repeats of these three variants. I solved it by rotating the minute counter finger on the chronograph (seconds) runner relative to the cam.  I'd be interested to hear your opinions on that. It seemed to be the right thing to do, but maybe I've introduced another problem I'm not aware of. * What is the correct relationship between the two hammers and cams, by the way? Should both hammers strike the cams exactly at the same time, or is it correct for the minute counter hammer to be a bit behind the seconds hammer? In this picture, I removed the adjusting screw at 1, and the hammers are contacting the cams simultaneously at 3 and 4. I had to turn the screw down tight to achieve this condition after stoning the seconds hammer and replacing the bridge.
    • It was easy enough to pop off. Once I had the cannon pinion hanging on the blades of the stump, I got my #2 tweezers on the gear attached to the staff and levered it down. That way none of the force was on the brass wheel itself.   I reinstalled it and the bridge, and it looks like a small but reasonable amount of end shake. It also spins easily with a blower. It stops quickly, but I think that's due to the large shoulder and about what I'd expect from this wheel.
    • Oh, right. For some reason I was picturing a monocoque case in my head. Good looking watch!
    • Well said Ross. My reason for the thread, i like many of us dont want to lose the forum, such a well knitted group of individuals i feel. But things can happen out of anyone's control. Would be nice to have something in place just in case, if anyone has any ideas please speak up.
    • Ok thanks Ross, I will give that a try!😁
