  • 0
Dpole
Pocket Watch
Question
Hi, like to put this one to all. I have striped cleaned and put back all parts up to the balance. Checked the piviots on the balance, connected the hair spring, fitted the roller and when fitted into the movement, I can not get it to swing.
Fitted the balance without any parts, put the bridge back and balance spins well. As soon as the roller is fitted and put back into the watch, nothing. Yes I have wound the watch, hair spring is in good order.
The only thing I can think of is there might be a problem with the roller.
Any ideas???????
Share this post
Link to post
5 answers to this question
  • 0
It might be the safety roller is in the wrong position. When the watch is static i.e. no power and the balance has settled the roller jewel should visually be centred in between the banking pins
Share this post
Link to post
  • 0
Hi clockboy, thanks for the info but the jewel is in between the banking pins, so I think the balance will be in beat. (when it moves).
The jewel is ok
Dave
Share this post
Link to post
  • 0
With the lever removed does the train run freely when some power is applied?
With the balance removed and some power on the mainspring does the lever snap smartly to the the banking pins when moved with a piece of pegwood?
Share this post
Link to post
  • 0
Hi autowind, thanks for info. The answer to your questions is yes the train runs very smooth and when the balance is removed and a little power supplyed  the pallet does move left and right and the escape wheel moved round. :jig:  I am having second thought about this, I think it might be down to the hairspring catching some where. any thoughts?
Dave
Share this post
Link to post
Answer this question...
Loading...
