8 hours ago, Plato said:
No way I'd reuse that part, it's already been mucked about with, replace it with a new pot. I bet the knob is a standard size used today.
https://uk.rs-online.com/web/c/passive-components/variable-resistors/potentiometers/?searchTerm=potentiometer
that was my first thought.  "This has been messed with" but it's old and this is my first machine, I thought it could have just been a bit crude.        I kind of want to replace it too.  Problem is like with your link you sent me, I don't know what replacement part I actually need.  I talked to Dave at Dave's Watch Parts and said he used to buy them at www.surplussales.com, but I still don't know exactly what to get.  115 volt at 75 cycles and I think it's 60 Ohm.
Edited by SonnyBurnett
I don't suppose you can find a circuit diagram? I sent the wrong link too, this is the correct link:
https://uk.rs-online.com/web/c/passive-components/variable-resistors/rheostats/
There must be something equivalent to what you need. But, like others have said, it might look/work a lot better when cleaned.
9 hours ago, SonnyBurnett said:
Dave contacted me and said this one might work.  Anyone got any thoughts?  Its on the very bottom of the page.
(RWA) A-29418-5
  https://www.surplussales.com//Potentiometers/Rheostats/PotsRheost-3.html.
Do you mean the (RWA) RP151SD750KK? I can't find (RWA) A-29418-5.
75ohm would be near enough to 60ohm for a rheostat provided it can cope with the current/power.
At the very bottom of the page in the link on the right side.  The last one.  On my screen it shows up as (RWA) A-29418-5
Rheostat, 800 ohm, 50 watt, 0.25 amp. Type R-50. 2-1/4" diameter body, 1-3/8" behind panel depth. 1/4" diameter x 1/2" long round shaft. Made by Memcor. NSN: 5905-01-013-4370.
Dave said this one is close enough it should work.  One thing I noticed is the wattage.  it's 50 watt and the machines are rated at 60.  Also the amperage, seems low.  Can't remember what the machine runs at.
Is this is the circuit diagram to your machine?
What motor does it use? We could figure out the current.
15 minutes ago, Plato said:
One thing I read about earlier was that some of these old rheostats might use asbestos as insulators, another reason to replace it.
Why. That would be another case of unjustified fears of a danger that scientifically doesn't exist when exposure to the harmful substance non-existent, as when asbestos is firs and solid, and in a minuscole amount. One needs years of continuous exposition to fibers to get in danger of developing lung cancer.
@jdm what part of the world do you live in that you don't consider asbestos a risk?!
Even a PhD won't be able to tell the correct value for the rheostat with the limited information given.
The value would depend on the internal resistance of the motor used in the machine. I'm sure the motor must have changed over the decades of production.
But 50 ohms does seem a little low.
7 hours ago, LittleWatchShop said:
Your hand drawn schematic is wrong at least in one place.  Furthermore, I measure the rheostat on my cleaning machine and it measures closer to 800 ohms.  And, yes, I do have a Ph.D. in electrical engineering.
It's not my diagram, I found it on the nawcc website.
I did ask about the motor.
In one where science is taught. I never said asbestos is not risky, but that it is in certain quantities and modes.
Fearing otherwise is unwarranted paranoia. Quote fron the first article I rant into:
A one-off exposure from do-it-yourself renovation is not a major risk
https://www.asbestos.com/exposure/short-term/
There is a major difference between asbestos in tons, or fractions of, and the scarce gram which could a sigle electronic insulator. Beside, isn't even proven than what is being discusses is indeed made of that.
Maybe a PhD doesn't, but people of practical experience do. As mentioned, 50 or 60 Ohm is little for any "power application".
    • The original 6139A manual is very clear in how to disassemble and how to assemble ...... step-by-step. However I haven't seen the 3169B manual, even in the Japanese version around, which clearly highlights the difference in center-wheel.   6139A Seiko Technical Guide.pdf 6139_A.pdf 6139A.pdf 6139b.pdf 6139B repair guide jp.pdf
    • Hi as an addition a pertaining to the assembly of a 6319B  which will be handy for those working on this caliber Polly's 6139 guide.pdf 6139A.pdf 6139B.pdf
    • Casio MDV106G-1AV Gold DURO200 I'm going on a long family vacation to Southeast Asia this summer and wanted a cheap but reliable beater in case I lose it, break it, or get robbed. Quartz movements aren't my thing, but I'm not dogmatic and this was a cheap option. A few years ago you could buy it for under $50, but since this particular model with the Marlin fish has been discontinued, you have to pay about double that, but I still thought it was acceptable. Sure, I could wear one of my cheap and very reliable Vostok Amphibian divers watches, but I have a personal relationship with them (having put a lot of work into them) and don't want to risk losing them. Strangely, I feel very excited. Maybe because I haven't bought a brand-new watch in over 10 years! 😀 The only downside is that this is the watch Bill Gates has been seen wearing, and I'm not exactly a fanboy of Bill Gates. Anyway, who cares!?
    • This post has some pictures that describe how to get the spring back into the setting without having to disassemble anything.  With patience, this approach works.  The advice that the spring will ‘float’ back in when positioned just right is spot on. If you try to push it so it flexes and pops back into the setting, it’ll probably just fly away, as you’ve already found.  Hope that helps, Mark
    • I recognize myself all too well. It takes a lot of experience and discipline to recognize when it's time to cancel and come back at a later time. Very well said! We should have a forum dedicated to this topic as it is critical to achieve success when working on watches. It's a lot more important than most other things related to watch repair. And yes, just a short break can make a world of difference!
