New to this art
Micheas
Hi every one Im from a small island in europe called Malta I always was intrested in watches but this last few months I end up constantly searching on watch movements, servicing and restorations.
About last month ago I took a leap of faith and started buying some tools and I found a shop which I think I might say he was a life saver. This profession in my country is dying and it was quite difficult to start but with a miracle I found this shop and his even helping me out with giving me broken and working movements to work on and gives me great tips too.
My first working watch that Im currently working on is  bfg 866 movement with date disc and to be onest with you I did not think that it was going to give me this much problems. After I replaced broken/lost parts I assembeld it again and to my surprise the minute and hour hands are not working know but I found the problem hopefully.
Apart from that I fell in love with this art. So thank you for having this forum as it is a great helping tool.
If you have any book suggestions about anything regarding watch movements and there history and any europen sites that sell parts and tools please let me know.
Thank you
Micheas
Edited by Micheas
Hello and welcome to the forum  Had a holiday on Malta (Selima) and enjoyed it very much. A very friendly place.  Regarding books etc  Henry B Freid, Donald de Carle. are the classics,  Videos UTube   posted by Mark Lovick  adminisrator of this site.  He has courses which will teach you how to repair/service watches. If you are serious in this endeavour enrol on the course.  Attached a little reading for you       cheers
1612608791_ToolsfortheHobbyist (2) (1).pdf TZIllustratedGlossary.pdf
1612608791_ToolsfortheHobbyist (2) (1).pdf 371.51 kB · 1 download TZIllustratedGlossary.pdf 4.2 MB · 1 download
Thank you for the info.
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Here is the fake .pdf for just the FreeCAD base file and 3mf files Modular Movement Holder.pdf Here is the fake pdf for complete set of the new base and ring FreeCAD/3mf files: Modular Movement Holder base and ring v 2.1.pdf However, I'm wondering how often you could use this feature, adding the dial usually increases the OD of the movement, so you would need a new (larger) adapter ring tuned to the OD of the dial and I wouldn't like to grip the dial in any kind of movement holder if It could be avoided for fear of damaging it. Maybe I'm misunderstanding you?
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
