Fitting crowns to a Smiths watch
PeterDRG
Hi
I´m Peter, a model engineer in Istria. I´m reasonably well equipped, with a Hobbymat MD65 and lots of accessories, a Hobbymat BF400 mill , a Boxford and lots of George Thomas stuff. I´m making a Chronos Wheel Engine, for which I already have the division plate and cutter head. I will be using it to make a weight driven brass alarm clock to the John Wilding design.
So much for the intro. (I couldn't get the intro page to work)
I have a Smiths wristwatch which I bought with money from my paper round 60 years ago. It is getting difficult to wind, as the crown is worn. I have a box of crowns in various sizes, but I have never worked on a watch before. Donald de Carle doesn't seem to say much about it. It is probably very simple, but I thought it safer to ask here first how to do it.
Are the destructions available anywhere, please ?
TIA
Cheers
Welcome here. Beginners often get associated with destructions, but I don't think that will be your case here. From our host Mark Lovick, if you want to learn practical watchmaking I recommend you enroll his training at watchfix.com
1 hour ago, PeterDRG said:
 A firm grip whilst holding the stem and it will wind off ?
Don't force anything. If the crown doesn't unscrew with moderate force heat up the pipe a bit to loosen any thread locking agent that may be ther.
Hi  Bear in mind jdm's advice regarding force and heating it up to release thread lock. Also be reminded that watch stems have Tap numbers relating to stems and stems differ in thread diameters and taps.  The site "windingstems.com"has a co784727683_TapSizeChart.jpg.b2fcc5aa830ae6c1516aa8b2cc08caf9.jpgmprehensive list of available stems also Cousins uk.  But cousins use a differnt tap system so check your stem before ordering
    • I need to see photos of the whole movement before I comment.
    • Hi @Jon, so, from one extreme to another the beat error is 0.1(min.pos) to 0.2(msx.pos), and as you mentioned the rate does up and down dramatically. Also checked the position of the collet, and the collet is not central to the jewel on the balance cock. Balance moves freely, per my understanding.   So, after 24h the ampl. fell down by approx 20 deg, which I would assume is expected. After adjusting the endshake I believe I gained around +10 deg. of balance movement. Which is great, and overall the balance is not at 220'ish deg.   What I did next, some might think is non-orthodox, but was wort a try. I too the mainspring out, checked again for endshake and if the pin moves freely, and cleaned everything. Usually when installing the mainspring I would use some barrel grease on the barrel walls, install the spring and put a 2-3 drops of D-5 oil on top of the wounded spring and in the places where the arbor sits. This time I took the spring and applied a ultra this coat of Molykote Dx paste on the whole spring, before installing it in to the barrel, and added some oil to the arbor as usual.  The result improved, at a full wound the balance produces about 230-237 deg. @JohnR725 I'm getting closer to 300 😃   What I am noticing, there is a fluctuation in amplitude. With time it would rise and drop about total 8-10 deg in an interval about 2 minutes. I assumed this ruled out the power transfer from the barrel itself. So I took the gear train out, cleaned and lubed.
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Here is the fake .pdf for just the FreeCAD base file and 3mf files Modular Movement Holder.pdf Here is the fake pdf for complete set of the new base and ring FreeCAD/3mf files: Modular Movement Holder base and ring v 2.1.pdf However, I'm wondering how often you could use this feature, adding the dial usually increases the OD of the movement, so you would need a new (larger) adapter ring tuned to the OD of the dial and I wouldn't like to grip the dial in any kind of movement holder if It could be avoided for fear of damaging it. Maybe I'm misunderstanding you?
