Pendulum
Willow
Got this French clock the other day not ready to work on it yet, need a pendulum for it also double ended key problem is i don't no the length of the leader or the weight of the bob.  Are the numbers at the bottom right the length of the leader, hope you can understand all that, can anybody advise me please.
I don't know about the numbers, but you can calculate the length with this calculator
https://theindex.nawcc.org/CalcPendulumLength.php
Weight is far less of an issue than length (effective length is what gives its frequency); what you'll find that's in the ballpark for length will almost certainly be OK for weight.
Yes you can get keys. This is the type key you need. The suspension springs also come in different sizes. If you have the old one measure the length.   Could you post a photo of where the s/s is fitted then I can be more precise on which one to buy. Any good suppler with stock both of what you need.
    • I would go for the dearer spring. You won't need to remove the spring from the carrier ring and then use a mainspring winder to get it into the barrel, for a start. Also that spring is closer to the needed dimensions, especially the length. The length plays a part in the mainsprings strength. If you double the length you will half the force (strength) of the spring and vice-versa. A spring with 20 mm less length would be about 7% shorter, so technically would be 7% more strength, but I find halving this number is closer to real-world findings, so the spring would be about 3 to 4% more strength/force. On a mainspring that ideally kicks out 300 degrees of amplitude, a 3% increase in amplitude would be 309 degrees. Increasing or decreasing the length of the mainspring will affect the power reserve to a greater or lesser degree. It depends how much shorter or longer it is. I've attached a lesson regarding mainsprings, focussing on the size and strength of the spring within the barrel, you might find helpful. Unfortunately it is a PDF converted from a PowerPoint presentation, but only a slide was lost that was originally a video of fitting a mainspring   Lesson 5 The mainspring.pdf
