Westclox Movement Riveted
Hi, guys! This is my first post on the forum as I am new. I hope I'll be able to get some help on here as I've just started my journey into watch repairing.
Anyway, I'm afraid I have an idea of what the answer will be but I thought I'd ask anyway:
I have an old Westclox Scotty pocket watch that wasn't ticking at all. I wanted to take it apart and try to see what was wrong with it but I noticed that it's not like a normal movement. It was riveted. Is it possible to take these rivets out without doing permanent damage to the "bridge", which is more like a cover plate than anything else? Or is this going to have to be a spare parts movement? I can post pictures if you need them.
Thanks in advance for the help!
-Guss
About the only thing you can do with these dollar watches is clean the entire movement as one piece, rinse very well, let dry very well and re lubricate.
Sorry, no, you will do damage if you try to remove the metal riveting leaving no metal left to re rivet. Also, the entire watch is put together as one unit. ALL the parts must be installed at one time. Hope that makes sense.
Yup that's the one! The  hairspring is pretty crooked. and I wanted to see if I could fix that. It started ticking after tinkering around with the gears, moving them to and fro and eventually it started. But it's sounds pretty off beat, which is why I want to try to fix the hairspring.
I'll try cleaning the movement as it is and lubricating it. I'll get back to you when I do that. Thanks for the help, guys!
-Guss
I agree with the posts so far the only way forward is the clean the whole movement dry thoroughly & re-lube.
This sometimes works I have used this method with cheap alarm clocks & it is surprisingly successful.
On the clocks I soak or wash with paraffin & blow dry them. But being a watch use something like lighter fuel as the hairspring must be perfectly dry and grease free after the clean.
I bought a pocket ben as my first watch and the seller told me it could not be repaired. I bought it took it home and repaired it with a set of screw drivers and eye tweezers from frys electronics. It was difficult for about an hour to put it back together but I did it and fixed the mainspring. They are very hard to put back together because there is only one plate to line up all the wheels. Good luck
    • Hi. Yes I get it , the slot in the end I’d to allow you to screw the button on whilst holding the pusher shaft. To remove the pusher tube you will need a tool such as the one shown by Richard. I think Ali Express the Chinese Amazon has replicas of the Horotec system for a lot less money, how effective they are not having had to use one. But as you said the way to go is complete removal and replacement, bodging it up will  lead to a repeat failure
    • It does look like it seems to be working again I'm getting emails.
    • One of the things that I've been bothered with lately is timekeeping? For instance a 90-year-old pocket watch what so to timekeeping was it supposed to keep? They publish railroad timekeeping but I don't know how well normal non-railroad watches were supposed to keep time. The reason why the question comes up for me is I spend a lot of time at work adjusting watches to keep really really good time  because I have to please my boss where as when the watch was made I have to wonder what kind timekeeping would've been acceptable. After all they typically didn't have timing machines 100 years ago and they were timing and six positions certainly not for the non-railroad grade watch. On the other hand I do get paid by the hour so maybe I shouldn't be concerned of how much time I Spend trying to make everything keep chronometer timekeeping almost. Citing a Delta of 40 seconds for a 90-year-old watch is quite outstanding.
    • That's an interesting question which I don't think I've seen explained anywhere. But I think the problem will go away just about instantaneously. In other words the  coating is really thin and it should go away almost immediately. So the problem should resolve itself extremely fast.
    • I experienced that different types of shellac and their ages are affected differently by IPA. Sometimes the shellac dissolves in a few seconds and sometimes several minutes are required. Nowadays I never let shellac come into contact with IPA. It's a hotly debated topic here on WRT if you search. Like John, I don't think you need to worry about the weight of the shellac, but instead that it might start rubbing against something. When I learned how to adjust pallet stones, I tried documenting my experiences in this thread. Hopefully, it can help you. I personally don't believe in the idea of abrading the epilame before oiling so I don't think you need to think or worry about it. The only time I've heard anyone mention this is Alex on the YouTube channel Watch Repair Tutorials but actually no one else. I'm not saying it's "wrong" just that I don't think it's necessary or adds anything.
