Westclox Movement Riveted
Hi, guys! This is my first post on the forum as I am new. I hope I'll be able to get some help on here as I've just started my journey into watch repairing.
Anyway, I'm afraid I have an idea of what the answer will be but I thought I'd ask anyway:
I have an old Westclox Scotty pocket watch that wasn't ticking at all. I wanted to take it apart and try to see what was wrong with it but I noticed that it's not like a normal movement. It was riveted. Is it possible to take these rivets out without doing permanent damage to the "bridge", which is more like a cover plate than anything else? Or is this going to have to be a spare parts movement? I can post pictures if you need them.
Thanks in advance for the help!
-Guss
About the only thing you can do with these dollar watches is clean the entire movement as one piece, rinse very well, let dry very well and re lubricate.
Sorry, no, you will do damage if you try to remove the metal riveting leaving no metal left to re rivet. Also, the entire watch is put together as one unit. ALL the parts must be installed at one time. Hope that makes sense.
Yup that's the one! The  hairspring is pretty crooked. and I wanted to see if I could fix that. It started ticking after tinkering around with the gears, moving them to and fro and eventually it started. But it's sounds pretty off beat, which is why I want to try to fix the hairspring.
I'll try cleaning the movement as it is and lubricating it. I'll get back to you when I do that. Thanks for the help, guys!
-Guss
I agree with the posts so far the only way forward is the clean the whole movement dry thoroughly & re-lube.
This sometimes works I have used this method with cheap alarm clocks & it is surprisingly successful.
On the clocks I soak or wash with paraffin & blow dry them. But being a watch use something like lighter fuel as the hairspring must be perfectly dry and grease free after the clean.
I bought a pocket ben as my first watch and the seller told me it could not be repaired. I bought it took it home and repaired it with a set of screw drivers and eye tweezers from frys electronics. It was difficult for about an hour to put it back together but I did it and fixed the mainspring. They are very hard to put back together because there is only one plate to line up all the wheels. Good luck
    • So here is the new base, I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded. The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool. Note, I think you may need to print supports for the new internal shelf created? Modular Movement Holder v2.pdf Modular Movement Holder v2.pdf
    • Hi Frank, you have dived headlong into the deep end. Hairspring work has to be the scariest thing a newbie has to tackle. Your hairspring appears to be bent and just putting it back into the regulator would not allow the balance to work properly. It might start oscillating but the performance would not be good. The proper thing to do is to unstud the hairspring, remove the hairspring from the balance, reinstall the hairspring on the stud carrier, reshape the endcurve and centre the collet to the balance jewel hole. This challenge would either make you or break you. Hope that you will be able to fix your watch. Welcome to the world of watchmaking.
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
    • Good job, that band matches the watch perfectly.
