Hello from Utah, and a question
Anza
Hello,
Im pretty new to watch repair, just a few watches serviced so far.  This forum has been a big help.
As for the question:  I’m in the middle of a Slava 2416, and have a reassembly issue with one of the mainsprings.  I was trying to rewind it, but after a rather epic battle, I now have a mainspring fit for the trash can.  I’ve had no luck trying to source a replacement, including the cousins site, and am hoping someone can point me in the right direction.  I found a donor Slava 2427 on eBay, but I don’t know if that’s compatible.
thanks for any help!
- Anza
OK in my GR catalogue it shows a Slava cal: 2414 and it’s mainspring is as follows:
GR 3919DB  the DB indicates it has a special bridal which is the shape of the start of the spring. It’s size is 1.45x0.075x240.
https://www.cousinsuk.com/category/filter/slava-movement-parts
Cousins also supply the above as a complete barrel.
The nearest size I could find re the sizes you have supplied is:
GR4059 1.50x0.07x240
https://www.cousinsuk.com/search?SearchTerm=gr4059
there is also a GR4059DBH which is another shape of the start of the spring but Cousins do not supply that spring.
You need to know the shape the spring see attached pic.
    • Oh nice. I have a similar wedge style stump for my staking tool, so I'll give that a shot. Thanks!
    • Thank you all for the replies!  Very informative! True enough, the Gamsol took some time to evaporate and does leave a residue. So not all naphtha are created equal!  Need to find alternatives then. i was able to try Hexane recommended by Alex and it seems great.  I wonder what the cons are?
