Elma Watch Cleaning Machine
Well that's teach me for opening the window, I just completed the final coats for the cast alloy parts, and the base which needed a final coat, like a numpty I opened the window to let the fumes out, its -15 out so now my base has some crystalisation on the one side, guess it added to its character.
Edited by SSTEEL
Damn its cold there!! It's around 12º here and i'm feeling it.
Thank you Mark and Micky for the measurements. I believe I'll be ordering too!
I hope the crystallization is not too bad! I used to live in Chicago and believe me I know what -12 is! The worst winter here in Miami is about 34 (all in Celsius)!
My OCD got the better of me so sanded the crystallisation area right down to the metal again ready to cost again.
It usually drops to as low as -35 in March/April.
Edited by SSTEEL
And I thought my old town was cold! By March we were already leaving behind the worst of the cold...worst part was February where deeps rarely would go to -40F or so with the wind factor...
So back to the Elma, nice move. After all you have put into it, it would be a shame not to re do the finish! I'm probably also OCD! :D
My little baskets arrived, and they are great, the lids snap on nice, and don't fall off.
15882659821_12b6b699d3.jpgUntitled by Micky.!, on Flickr
15698880477_1567202949.jpgUntitled by Micky.!, on Flickr
Got myself a new, smaller digital camera too recently, taking sometime getting used to it, but overall its great compared to my old thing I had, it was way too bulky.  I went for the Sony Cybershot WX350.
Yep, just the wiring, and a little thing called "time"  :)  Finding time these days is hard, I am so busy with work, but I need to make time, as this Super Elite will indeed be ut to work right way too.
The mechanical timer that mine had fitted was ok, but the cream coloured dial put me off in refitting it to my refinished look, so have purchased a modern-day digital turn to set round timer, which hopefully will fit in the recess, plus give me more room for the wiring behind there too.
I'm looking forward to seeing that.
These days I use the coundown timer on my iPhone ;)
My timer arrived, and its almost a perfect fit, just need to modify the old timer surround so this timer protrudes through and allows rotation of the outer setting ring.
15711031789_abf79a44c5.jpgUntitled by Micky.!, on Flickr
15711030429_7341771a17.jpgUntitled by Micky.!, on Flickr
15711294417_e9077e4301.jpgUntitled by Micky.!, on Flickr
Need another clear coat on this case part too by the looks of it.  Getting excited now, almost there, planning on starting the rewiring the weekend.
    • Hold the crown when in winding position, move the click away from the crown wheel, and then while holding the crown let it slowly unwind. I recollect that you must remove the automatic device bridge first, but maybe I'm wrong. You can first try without removing the automatic device bridge.
    • nevenbekriev- You nailed it with your description of me and my reaction when the clock started ticking again. I am a newbie.  I love the sound and idea of mechanical clocks but the idea of owning one and trying to keep them running has never appealed to me. My wife bought this one and an antique German wall clock.  When I looked into having someone repair them for me, the universal response was "it's really expensive to work on them, you should just replace the movement". So, I had nothing to lose, I started researching them and opened them up. The wife is happy because she hears the sound of the clocks again. But I have gone down the "accuracy" rabbit hole. In the vertical position, the balance wheel was not floating. It was sitting on the bottom of the frame. I adjusted the lower spring collet and got it floating. It easily passed the 270 degree 3 to 5 minute oscillation test. It took 8 minutes for the wheel to completely stop moving.  I put it the unit back in the movement and checked the safety pin. It does not touch the safety roller anywhere in +/-270 degrees rotation from neutral position. But the amplitude of the rotation with the spring fully wound is weak based on what you are saying. It rotates +/-90 degrees from the neutral position.  No, I did not take the movement completely apart.  That seemed way outside my skill set at the time. There is a reason I became an electrical engineer and not a mechanical engineer. I am much more comfortable with moving electrons than tiny moving metal parts. Will I do it in the long run? Anything can happen. I don't seem to be able to let it go.
    • Isn't that the same guy who told Zelenskyy to escalate the war with Russia/Putin when they already had a peace deal? 2 years later and we have half a million young Ukranian boys dead. He doesn't seem very clever...
    • Thanks guys.  quick question. For automatic movement, particularly this one. can I power down the main spring by pushing this rachet down?  i've gotten pretty used to SW210 and powering down a manual movement. But so far i've only been waiting for the auto movement to run out of juice before opening the case.
