Elma Watch Cleaning Machine
Well that's teach me for opening the window, I just completed the final coats for the cast alloy parts, and the base which needed a final coat, like a numpty I opened the window to let the fumes out, its -15 out so now my base has some crystalisation on the one side, guess it added to its character.
Edited by SSTEEL
Damn its cold there!! It's around 12º here and i'm feeling it.
Thank you Mark and Micky for the measurements. I believe I'll be ordering too!
I hope the crystallization is not too bad! I used to live in Chicago and believe me I know what -12 is! The worst winter here in Miami is about 34 (all in Celsius)!
My OCD got the better of me so sanded the crystallisation area right down to the metal again ready to cost again.
It usually drops to as low as -35 in March/April.
Edited by SSTEEL
And I thought my old town was cold! By March we were already leaving behind the worst of the cold...worst part was February where deeps rarely would go to -40F or so with the wind factor...
So back to the Elma, nice move. After all you have put into it, it would be a shame not to re do the finish! I'm probably also OCD! :D
My little baskets arrived, and they are great, the lids snap on nice, and don't fall off.
15882659821_12b6b699d3.jpgUntitled by Micky.!, on Flickr
15698880477_1567202949.jpgUntitled by Micky.!, on Flickr
Got myself a new, smaller digital camera too recently, taking sometime getting used to it, but overall its great compared to my old thing I had, it was way too bulky.  I went for the Sony Cybershot WX350.
Yep, just the wiring, and a little thing called "time"  :)  Finding time these days is hard, I am so busy with work, but I need to make time, as this Super Elite will indeed be ut to work right way too.
The mechanical timer that mine had fitted was ok, but the cream coloured dial put me off in refitting it to my refinished look, so have purchased a modern-day digital turn to set round timer, which hopefully will fit in the recess, plus give me more room for the wiring behind there too.
I'm looking forward to seeing that.
These days I use the coundown timer on my iPhone ;)
My timer arrived, and its almost a perfect fit, just need to modify the old timer surround so this timer protrudes through and allows rotation of the outer setting ring.
15711031789_abf79a44c5.jpgUntitled by Micky.!, on Flickr
15711030429_7341771a17.jpgUntitled by Micky.!, on Flickr
15711294417_e9077e4301.jpgUntitled by Micky.!, on Flickr
Need another clear coat on this case part too by the looks of it.  Getting excited now, almost there, planning on starting the rewiring the weekend.
    • OK, welcome in the world of alarm clocks... I guess the 4th wheel is dished because it is from another movement. If it was not dishet, then it would not mesh with the pinion of the escape wheel, am I right? The marks of wear on the 4th wheel pinion doesn't corespond to the 3th wheel table position, at list this is what i see on the picts. Calculating the rate is easy - there is a formula - BR = T2 x T3 x T4 x T5 x 2 /(P3 x P4 x P5) where T2 - T5 are the counts of the teeth of the wheels tables, and P3 - P5 are the counts of the pinion leaves. Vibrating the balance is easy - grasp for the hairspring where it should stay in the regulator with tweasers, let the balance hang on the hairspring while the downside staff tip rests on glass surface. Then make the balance oscillate and use timer to measure the time for let say 50 oscillations, or count the oscillations for let say 30 seconds. You must do the free oscillations test to check the balance staff tips and the cone cup bearings for wear. This kind of staffs wear and need resharpening to restore the normal function of the balance.
    • Glue a nut to the barrel lid, insert a bolt, pull, disolve the glue.  Maybe someone will have a better answer.
    • The stress is the force (on the spring) x distance. The maximum stress is at the bottom, and decreases up the arm. That's why they always break at the bottom. I used a round file, then something like 2000 grit to finish. I gave the rest of the arm a quick polish - no need for a perfect finish. Just make sure there are no 'notches' left from cutting/filing. The notches act like the perforations in your toilet paper 🤣
    • It's probably a cardinal rule for watch repair to never get distracted while at the bench. Yesterday, after finishing a tricky mainspring winding/barrel insertion (I didn't have a winder and arbor that fit very well) I mentally shifted down a gear once that hurdle was passed. There were other things going on in the room as I put the barrel and cover into the barrel closer and pressed to get that satisfying snap. But when I took it out I realized I never placed the arbor.  When opening a barrel, we are relying on the arbor to transfer a concentrically-distributed force right where it is needed at the internal center of the lid. However, when that isn't present it's difficult to apply pressure or get leverage considering the recessed position of the lid, the small holes in the barrel and the presence of the mainspring coils. It was a beat-up practice movement so I didn't take a lot of time to think it over and I pushed it out using a short right-angle dental probe placed in from the bottom, but that did leave a bit of a scratch and crease in the thin lid. I had also thought about pulling it using a course-threaded screw with a minor thread diameter smaller than the lid hole and a major diameter larger, but that may have done some damage as well.  Thinking about how this might have been handled had it been a more valuable movement, is there a method using watchmaking or other tools that should extract the lid with the least damage?
    • 🤔 what happens if lubrication is placed directly on top of epilame ? Making a small groove so the lubrication doesn't spread across the component but what if when lubing a little overspills and sits on the epilame .
