Elma Watch Cleaning Machine
Its getting exciting now Geo, I have finally decided to etch, and coat the casing parts with a few layers of clear lacquer, after all the hard work of removing all the paint, and all the wire wool, and sanding work, it would be a shame to hide it all under a colour paint :)
I have taken photographs of the wiring, so I know how to rewire it, I did initially plan on replacing the large speed controller, but I think I will reuse it as its still working, so too is the motor, and the heater, the latter looks newer than the other components, so I would imagine the heater has been renewed at some point.
Edited by SSTEEL
I am so impressed - it's going to be like a new machine.
Now I wonder - would it be beneficial to coat the inside of the drying chamber with that heat resistant car paint, the one you would use on an engine for example. Probably overkill?
Maybe even under the heating element too - to prevent corrosion?
Starting to think maybe I should of started a separate thread for my Elma Super Elite restoration.
Anyway, new varnish in, and final parts now after two coats, a final coat on everything, then will polish the parts to remove any overspray.
15607567849_a9bc0cc8c3.jpgUntitled by Micky.!, on Flickr
15607989078_c8c34f4425.jpgUntitled by Micky.!, on Flickr
15793391765_635f4b2fc8.jpgUntitled by Micky.!, on Flickr
15173955973_a11edd0493.jpgUntitled by Micky.!, on Flickr
15607570279_414f3e1580.jpgUntitled by Micky.!, on Flickr
15173440034_59b106f91c.jpgUntitled by Micky.!, on Flickr
And a few shots now the clear varnish has dried :)
15609339097_738cf6d1bc.jpgUntitled by Micky.!, on Flickr
15770825626_e2e2b0ca0a.jpgUntitled by Micky.!, on Flickr
15609661890_93c07e0047.jpgUntitled by Micky.!, on Flickr
15608676819_7899de3bb1.jpgUntitled by Micky.!, on Flickr
The cast alloy parts, although come out ok, they are not as glossy and smooth as the aluminium case parts, so will need a few more coats tomorrow.
15794505745_67e232b52f.jpgUntitled by Micky.!, on Flickr
15770829526_5d8ee02e71.jpgUntitled by Micky.!, on Flickr
15609098308_d64dfabaef.jpgUntitled by Micky.!, on Flickr
15175067273_d26cf5763d.jpgUntitled by Micky.!, on Flickr
And the base needs one more coat...
15794508715_542d01acde.jpgUntitled by Micky.!, on Flickr
15609347137_884263aecf.jpgUntitled by Micky.!, on Flickr
15794510935_b5178bbf1d.jpgUntitled by Micky.!, on Flickr
Edited by SSTEEL
Lovely gloss finish you have there Micky, when does assembly start?
Thanks, all being well rewiring will start next week, quite busy with work during the week, so only have time at the weekends.
I love how it is coming out! Great job!
Thank you :)
Thanks, the wiring looks like a nightmare, but luckily I was wise enough to take photos of the various wiring, and connections which should help the rewiring :)
Anyhow, some goodies in from Cousinsuk..
Complete basket, this is the alternative to the obsolete Elma item..
15812312405_15a73d4717.jpgUntitled by Micky.!, on Flickr
15627463660_2f33fce27c.jpgUntitled by Micky.!, on Flickr
Gasket for the Motor (Seals baskets in the jars, preventing spash-back.
15626912998_a1dbe93865.jpgUntitled by Micky.!, on Flickr
Heater switch..
15810428181_0655d289c5.jpgUntitled by Micky.!, on Flickr
And new bulb.  I was contemplating fitting a modern motor speed adjuster, and LED light but seeing as the old parts are still working, I serviced them, and they should be fine for some yers to come all being well..
15812315875_0c49552757.jpgUntitled by Micky.!, on Flickr
OK - I'm jealous, I want a blue basket!!! Mine is boring grey.
:D
Top tip: If you ever need more of the little baskets (you can never have enough IMO) then I usually buy them from this guy - quarter of the price of Cousins:
http://www.ebay.de/itm/Siebkapsel-z-B-fur-Elma-Reinigungsmaschinen-/141412294943?pt=Uhrmacherwerkzeug&hash=item20ecd4611f
Wow! Nice and professional! Micky that's one mean machine you are putting together! I bet it will be better than new! Keep it up, great job! If I were a watch I'll be anxious to get a bath in that machine!
@Mark: Hi Mark, nice link, how do they compare in size to the Bergeon ones? I'd like to buy a couple myself!
Edited by bobm12
Sorry Bob, but I never purchased the Bergeon ones so I can't compare.
Nice link Mark wondering if they fit the L&R
Yes - I think they do fit the six compartment tray.
    • The entry jewel's not as bad but seems still too much lock. I do epilame the escape wheel and pallet jewels, then run dry for about 15 minutes, then put 9415 in exit jewel very little at a time and check with backlight how the oil's distributed.  Another question is about capped escape wheels. Should I somehow wear the epilame off the pivots before installing the wheel? I normally let the escape wheel run dry for that said 15 minutes when there's no cap jewel.
    • Sometimes there's a certain place under the bezel where the case knife is supposed to be placed. In this borrowed pic there's a small crack at 3 o'clock.
    • Hi my fellow forum addicts, I'm writing this as I seem to have a hole in my knowledge (probably one of many!) I seem to have a horrible time removing bezels from watches. I am talking about the rotating type on sports/diving watches. I see many videos where the guy on screen barely inserts the case knife under the bezel and with no effort it pops off easily, then at the end it clicks back into place by hand with no effort. I am sure that part of this is due to skillful video editing, but I seem to wrestle with them, I have tried case knives and  even when using the tool below, I tighten it up in several positions and nothing happens. On a many occasions I have even warped the bezel in my attempts to remove it. Similarly, I have issues replacing bezels after cleaning etc. and often they have to be replaced using a press tool and inevitably are far too tight and will not rotate or loose to the point where they fall off or loose their click (perhaps due to micro warping when I tried to remove??). It is now to the point where I am actually avoiding watches with bezels as my success rate with them is terrible......please help!! In short I am asking: What am I doing wrong? What is the best method for removing bezels - how do you do it? What is the best method for replacing bezels - how do you do it? Any tips or tricks? Thanks
    • Amplitude still seems low, but I'm going to let it run in a bit and revisit. Meanwhile, got the first layer of the calendar works together and made sure the date ring snaps to both in quickset and regular setting. The mechanism is pretty cool, so I took a video.
    • This is the part that need replaced if anyone can point me in the right direction.
