Elma Watch Cleaning Machine
Its getting exciting now Geo, I have finally decided to etch, and coat the casing parts with a few layers of clear lacquer, after all the hard work of removing all the paint, and all the wire wool, and sanding work, it would be a shame to hide it all under a colour paint :)
I have taken photographs of the wiring, so I know how to rewire it, I did initially plan on replacing the large speed controller, but I think I will reuse it as its still working, so too is the motor, and the heater, the latter looks newer than the other components, so I would imagine the heater has been renewed at some point.
Edited by SSTEEL
I am so impressed - it's going to be like a new machine.
Now I wonder - would it be beneficial to coat the inside of the drying chamber with that heat resistant car paint, the one you would use on an engine for example. Probably overkill?
Maybe even under the heating element too - to prevent corrosion?
Starting to think maybe I should of started a separate thread for my Elma Super Elite restoration.
Anyway, new varnish in, and final parts now after two coats, a final coat on everything, then will polish the parts to remove any overspray.
15607567849_a9bc0cc8c3.jpgUntitled by Micky.!, on Flickr
15607989078_c8c34f4425.jpgUntitled by Micky.!, on Flickr
15793391765_635f4b2fc8.jpgUntitled by Micky.!, on Flickr
15173955973_a11edd0493.jpgUntitled by Micky.!, on Flickr
15607570279_414f3e1580.jpgUntitled by Micky.!, on Flickr
15173440034_59b106f91c.jpgUntitled by Micky.!, on Flickr
And a few shots now the clear varnish has dried :)
15609339097_738cf6d1bc.jpgUntitled by Micky.!, on Flickr
15770825626_e2e2b0ca0a.jpgUntitled by Micky.!, on Flickr
15609661890_93c07e0047.jpgUntitled by Micky.!, on Flickr
15608676819_7899de3bb1.jpgUntitled by Micky.!, on Flickr
The cast alloy parts, although come out ok, they are not as glossy and smooth as the aluminium case parts, so will need a few more coats tomorrow.
15794505745_67e232b52f.jpgUntitled by Micky.!, on Flickr
15770829526_5d8ee02e71.jpgUntitled by Micky.!, on Flickr
15609098308_d64dfabaef.jpgUntitled by Micky.!, on Flickr
15175067273_d26cf5763d.jpgUntitled by Micky.!, on Flickr
And the base needs one more coat...
15794508715_542d01acde.jpgUntitled by Micky.!, on Flickr
15609347137_884263aecf.jpgUntitled by Micky.!, on Flickr
15794510935_b5178bbf1d.jpgUntitled by Micky.!, on Flickr
Edited by SSTEEL
Lovely gloss finish you have there Micky, when does assembly start?
Thanks, all being well rewiring will start next week, quite busy with work during the week, so only have time at the weekends.
I love how it is coming out! Great job!
Thank you :)
Thanks, the wiring looks like a nightmare, but luckily I was wise enough to take photos of the various wiring, and connections which should help the rewiring :)
Anyhow, some goodies in from Cousinsuk..
Complete basket, this is the alternative to the obsolete Elma item..
15812312405_15a73d4717.jpgUntitled by Micky.!, on Flickr
15627463660_2f33fce27c.jpgUntitled by Micky.!, on Flickr
Gasket for the Motor (Seals baskets in the jars, preventing spash-back.
15626912998_a1dbe93865.jpgUntitled by Micky.!, on Flickr
Heater switch..
15810428181_0655d289c5.jpgUntitled by Micky.!, on Flickr
And new bulb.  I was contemplating fitting a modern motor speed adjuster, and LED light but seeing as the old parts are still working, I serviced them, and they should be fine for some yers to come all being well..
15812315875_0c49552757.jpgUntitled by Micky.!, on Flickr
OK - I'm jealous, I want a blue basket!!! Mine is boring grey.
:D
Top tip: If you ever need more of the little baskets (you can never have enough IMO) then I usually buy them from this guy - quarter of the price of Cousins:
http://www.ebay.de/itm/Siebkapsel-z-B-fur-Elma-Reinigungsmaschinen-/141412294943?pt=Uhrmacherwerkzeug&hash=item20ecd4611f
Wow! Nice and professional! Micky that's one mean machine you are putting together! I bet it will be better than new! Keep it up, great job! If I were a watch I'll be anxious to get a bath in that machine!
@Mark: Hi Mark, nice link, how do they compare in size to the Bergeon ones? I'd like to buy a couple myself!
Edited by bobm12
Sorry Bob, but I never purchased the Bergeon ones so I can't compare.
Nice link Mark wondering if they fit the L&R
Yes - I think they do fit the six compartment tray.
    • Well done, let us know how you get on with the citizen.
    • @Neverenoughwatches Rich, I can only agree with you wholeheartedly. I spend a lot of time here learning all sorts and trying to make any little contribution to help others I can. Nothing can last forever and I wish I could do more to contribute to the forum financially and any other support I could.   Tom
    • This forum is a big part of my life. When I retired from horology many years ago due to poor health I missed what I had trained for. On here I can still do my bit in helping and advising others and have a little fun as well.
    • First thing this morning, make coffee, second, check the forum.  I would really miss the forum, not on any social media, not interested in telling the world what I had for breakfast!!! I do consider most of the regulars friends and would wonder what had happened if they stopped posting.
    • Hi all Thought I'd show my small and trying to keep under control watch collection! Apart from the Enicar all were under £12! At least if I destroy them in the process then I won't be too worse off. A few pics to start off with First of all my first attempt. A Thuya pocket watch. It was only running face down and would stop when vertical. So now it still works face down and only slows down when vertical so at least an improvement! 😄  I only have a generic watch oil at the mo so that won't help but I'm hoping to get some more appropriate oils in a couple of months for my birthday. I did have to get a crystal for it since it didn't come with one. It didn't look as though it would friction fit (and I don't have a crystal press in any case) so I glued it to the case with PVA. So far so good. Next up above are a sekonda and citizen automatic. Both non runners. Both with broken balance wheels amongst other things. I'm hopeful the citizen will start when I get the new one I ordered but the sekonda is being kept for spares and trial of new techniques. And finally the Enicar and the timemaster. Both running when I got them. I wanted to get running watches so that at least I stood a fighting chance of still having a running watch after the service! It was all going well on the Enicar until I dropped the balance wheel during reassembly...😔. Unfortunately they are quite expensive to get so for now I'll won't do anything with it but I would like to fix it at one point. The timemaster is still running (yeah!) but I managed to break a dial foot during the deassembly. First repair attempt failed so now I am looking at soldering it back on... So there we go. My initial foray into this great hobby. Thanks for sticking with this tale so far.  I'm hoping that once the balance wheel arrives for the citizen I will be able to say I bought a non runner and fixed it! So fingers crossed. Thanks for looking, Nick
