Elma Watch Cleaning Machine
6 hours ago, LittleWatchShop said:
I need to see more pictures. There appears to be only two wires connected to the speed controller. Is that right?
The speed controller looks like a wire wound rheostat. It varies from 0 to R ohms. R is probably in the range of 500 to 2000 ohms SWAG. Lowest speed when R is dialed in and fastest when 0 is dialed in.
I am troubled by the fuse blowing. No setting on the rheostat should cause that, so even if it is damaged in some way causing 0 or R, it would not blow a fuse. However, if one of the wires is shorted to the case, then you might blow a fuse...and this is possible due to physical damage.
I would unplug power and remove the rheostat and inspect it...post pictures.
I will get the right tools to remove the rheostat and I will shoot some better pictures. Any parts you would specifically want photos of?
Just want various views of the rheostat. Possibly moot I'd the axle is broken from the rheostat frame. If you have an ohm meter, measure the resistance through the outside terminals. You will need that info to get a replacement.
10 hours ago, GaspardColigny said:
I think there is something wrong with this connection. The blue wire of the incoming AC doesn't seem to be connected to anything.
And on the other side, the blue wire is connected to the live wire. There is a green/white wire, which should be ground, that is connected to the last terminal.
Check that out carefully.
If I can guess here that the wires on the top are colored correctly, then we have the neutral connected to the hot and the hot connected to the 3rd terminal.  But the 3rd terminal also has the case earth ground for some part of the case.  And the earth ground from the cord is connected to the case too.  Since the heater or motor don't actually care which is hot and which is neutral, we do have a circuit here.  Hot/brown to blue to the motor/heater to brown to earth ground wire to the case to the earth conductor in the cord.
Of course using the earth line as the neutral return isn't allowed.  And will trip a RCD or GFCI.  But the electrons don't care and will follow this path.
Yes, the wiring is a bit of a hot mess, I will have to rewire and resolder it, will have to pick up the right equipment at a friend first.
Will do, hopefully my friend has a multimeter lying around as well.
First time soldering, I reattached the spring to the Rheostat, Multimeter showing correct Ohm readings.
Then I started rewiring, I've attached 3 photos, and the schematic earlier in this thread.
I'm fairly sure about the neutral and live wiring ( O and P on schematic respectively)
L = Light
SH = Switch heater
SM = Switch Motor
However I'm uncertain about the connection on the base plate leading to the heater element. If I read the schematic correctly, should a wire run from the Light, connecting up to the blue/neutral for the Heating element on the base plate?
  • 2 months later...
Hi all, It's taken a year or so (time just gets away from you) but the rusted, beaten up, non working Super Elite is now 95% completely restored.  Powder coated in "Marigold", it will look good in the study. However that 5% remaining is 232909394_ElmaSEFinished.thumb.jpg.5c471c535b09c88d4215e694ef0fa3e2.jpgbugging me.
One thing I wasn't able to do is find a red lens for the bulb holder or a clear photograph of an original Elma decal (the gold and blue one from the older machines). If anyone can provide one, sell one or flick over an image that would be magic.
Cheers and thanks to everyone on this site.  Other restorations and general data makes life so much easier than doing everything oneself.  Better outcomes to.
Thanks, John
PS. I still need to polish the heater cover.... next weeks chore.
Looking at the photo that @Marcposted above makes me wonder if you couldn't start with one of those, put in an offset pivot for a larger turntable and rig up a spindle to a standard Elma basket stack and end up with a watch cleaning machine for less than £11,995.00,
  • 3 months later...
Hi there:
First off, my name is Nelson, and I'm trying to advance in this wonderful watch repair world (as a hobby, not as a career :-). I recently bought an Elma Super Elite machine with some wiring problems, and I can't seem to find how to wire the heating element. Should I cut the black wire coming from the wall plug and connect each end to one of the white cables coming from the heater? I saw some remnants of the old wiring and that seems to be the case, but I don't know if that even makes sense. As you guys may have already guessed, I have ZERO knowledge in electricity/electronics, and would very much appreciate any help you can give me. Thanks a ton in advance.
Nelson.
10 hours ago, Nacunad said:
Hi there:
Nelson.
Show us lots of pictures of the current state of your machine and we will try to help.  Do you own a multimeter?
  • Mark unpinned this topic
  • Mark pinned, unpinned and featured this topic
    • See, what has happen is a normal consequece of the reducing the hammer size and changing it's shape by the removing metal from it. But here the hammer is adjustable and just adjustment is needed to correct, and this is what You have done. There is a rule for the adjustment and it is that the hammer must lay firmly on the seconds counter heart and there should be a litle free play in the same time of the minutes counter heart/hammer which alows counter movement of about 0.5 min on the small dial hand (+/- 0.25). Of course, there is no way to make one hammer to delay from the other, as they are one single part. What has changed too is the slope of the hammer head and thus the orientation of the heart has changed, and thus the switching finger position. This led to need of the finger position correction. The rule here is that switching of the minute counter has to start when the seconds counter hand is on '59'. Of course, the seconds hand must be positioned as so the resetting is at '0' exactly. If switching is earlier than 59, there will be no problem, but it will be wrong as reading can be not correct. If the switching starts later, the problems that You described can happen.
    • Thanks, This watch was in a box of old scrape units that a friend gave me. They used to be his late father's who was a watchmaker before the war and then continued later in life. I picked this one out as it looked like it had potential, and I liked the dial, it's been a bit of a learning curve for a beginner but I was determined to get it going. Now I'm on the final lap it feels good. I'm just wondering whether to invest in a decent set of hand placement tools or stick with the cheap Chinese red thing I have, decisions decision 😆
    • An update, for everyone who contributed advice, and for those who come after with a similar problem. Based on the answers received, I decided to work on the face of the hammer first. I used a square degussit stone to guarantee a vertical surface to work against, and ground the face back until it was square across 90% of the depth. I was conscious of the risk of removing too much material.* After I'd got the shape how I wanted it, I polished the surface with lapping film. To cut a long story short, it did the trick and the hammer hasn't slipped off the cam since. Of course, that wasn't the end of my problems. Have a look at this video and tell me what you think is wrong. https://youtu.be/sgAUMIPaw98 The first four attempts show (0 to 34 sec.) the chrono seconds hand jumping forwards, the next two attempts (35 to 47 sec.) seem "normal", then on the seventh attempt (48 to 54 sec.) the seconds hand jumps to 5 sec. and the minute counter jumps to 1. The rest of the video just shows repeats of these three variants. I solved it by rotating the minute counter finger on the chronograph (seconds) runner relative to the cam.  I'd be interested to hear your opinions on that. It seemed to be the right thing to do, but maybe I've introduced another problem I'm not aware of. * What is the correct relationship between the two hammers and cams, by the way? Should both hammers strike the cams exactly at the same time, or is it correct for the minute counter hammer to be a bit behind the seconds hammer? In this picture, I removed the adjusting screw at 1, and the hammers are contacting the cams simultaneously at 3 and 4. I had to turn the screw down tight to achieve this condition after stoning the seconds hammer and replacing the bridge.
    • It was easy enough to pop off. Once I had the cannon pinion hanging on the blades of the stump, I got my #2 tweezers on the gear attached to the staff and levered it down. That way none of the force was on the brass wheel itself.   I reinstalled it and the bridge, and it looks like a small but reasonable amount of end shake. It also spins easily with a blower. It stops quickly, but I think that's due to the large shoulder and about what I'd expect from this wheel.
    • Oh, right. For some reason I was picturing a monocoque case in my head. Good looking watch!
