Elma Watch Cleaning Machine
Cheers Mark, so I have wired the lamp up wrong by the looks of it, can you tell me which is heat on, and hear off' position?  Left off, right on?
Heat is on with my switch to the right, but in this position I cannot get the motor to spin, its only spinning with the heat switched to the left, heater off.
Ah, it works when pushed down, and baskets in the heater chamber though :)
Edited by SSTEEL
Yes the heater and light should come on when the heater switch it flicked from left to right.
The motor is independent and comes on regardless of wether the heater is on or not.
Unless the heater is on, then no light appears when the motor is switched on.
Hope this helps.
Ok, that certainly helps, I need to recheck the lamp  wiring, as I have obviously missed something, and wired it up wrong, but at least everything is working as it should be, except the light, I will check the bulb first, as I have a new one here to fit.
Fitted the digital timer, but not exactly how iI planned, I removed the wide cone shaped base which was screwed on.
15884799157_c9e40236eb.jpgUntitled by Micky.!, on Flickr
And would you believe it, when my curiosity got the best of me, I trial fitted the timer into the circular void, and it was as if it was made to measure, it even clicked into place firmly, and is now good to go, it sits proud, so I will see how I get on with it, I can always fit it behind the face plate at a later date should I want to.
15450894753_e16c2235ca.jpgUntitled by Micky.!, on Flickr
16070561315_b61ba7249f.jpgUntitled by Micky.!, on Flickr
Edited by SSTEEL
I knew that new knob would just do it! Only kidding! :)
This is an awesome project and the result exceeding expectations...or maybe not?, considering the attention to detail, care, money, time and amount of work and preoccupation you put into it, Micky! Superlative results!
All I'm expecting now is for it to lift off and travel to the next galaxy...but then you will be getting the Nobel Price in Rocket Science not in Horology which is not the same thing and not that desirable anyway! Congratulations on a perfect executed restoration and, wow, amazing results!
My most heartfelt congratulations,
Cheers,
Bob
I figured it would Micky, and proud of your achievement. Very few people would have done such a thorough job! It has been a real labor of love and the results better than the original!
Any project in mind? I'd love to see how the parts come out! Please, take some before and after pics. Of course, I understand that cleaner types have a bearing in the outcome and you will probably be experimenting to obtain optimal results...just as I do! Does it ever ends? I hope not since the fun will be over!
Cheers,
Bob
I will be carrying out some test cleaning first before I start cleaning a complete movement, I want to get a feel for the machine, and see the results so I know what to expect, and what it can do for me.  I hope that makes sense?  Yes, I could throw any number of disassembled movements I have ready for cleaning, but I do want to test it out first, my curiosity needs satisfying :)
Thats my thinking Mark.  Although the blue basket frame fits the old Elma holder, it's fiddly to fit, and remove the basket each time, so may as well get the matching holder.
Seasons Greetings to you and your family Mark.!
Hows your workshop relocation going btw?
Edited by SSTEEL
Sounds like you need to build yourself a shed then Mark.  I have pretty much got my workshop just how I like it now, but we have to move out of aour apartment in April for a remodel, and need to set up in our temporary apartment, and then move back into our home in July, really really not looking forward to this move, I can tell you that much!
Hope you all had a fab Christmas.  I finally got round to fitting my new Elma basket retainer, and oh boy, (Sam Beckett voice), it was not a straight bolt on fit.  That's what I first thought, but after some light sandpapering the motor shaft after removing the old retainer, some added grease, I was then able to slide the new retainer on, but it would not go all the way onto the shaft.
What I ended up having to do is to place a small metal die on top of the heater chamber lid, lower down the shaft and new retainer ensuring the springs were free of the die, and then gently tapped the shaft from the top until it was in the correct position on the shaft, which as you know is very important for jar depth clearance.
Anyway, onto some photos, I know you all like photos, myself included :)
Old retainer removed.  (If anyone wishes to buy this, drop me a pm).
15962092350_9ea7d64da0.jpgUntitled by Micky.!, on Flickr
Then the new one fitted.
15527067434_2819511625.jpgUntitled by Micky.!, on Flickr
15961963488_6b94c2717a.jpgUntitled by Micky.!, on Flickr
And basket trial fitted..
15963337989_23a6e2f0f1.jpgUntitled by Micky.!, on Flickr
We had another foot of snow overnight, and its still snowing out, temps got down to -18, but that was it for now, its +3 today, and the snow is wet.  March and April is when we get the real cold, -35 :)
May I take this opportunity to wish each and every one of you all the very best for 2015.!
    • Never and others. Yes like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
    • Get someone local to tig it ,very easy fix and should only take a few minutes so probably wouldn’t cost much ,or failing that get it very clean and silver solder it. Dell
    • Hi, The winding pin is not split, well that's how it was when I obtained the watch. The movement is front-loaded and here's a picture of where the case screws are fitted. The face picture is before I dismantled it. Quick update.  I've always had a nylon ring sitting in the parts try that I wasn't sure where it went and left it to the last thing as I know it must be part of the case assembly. Anyway, looking at the picture in my last post you can see, just under the winding stem, a white-looking object, this is the nylon ring 🤭 So, I had to remove the dial again and replace the ring. Once this was all back together I placed the movement in the case and realized my initial problem maybe is not a problem as it looks like I can screw the movement back in the case and then place the hands as the dial is nearly flush with the outside of the case anyway so I'll be able to check for alignment. if all is good then just fit the crystal and bezel 🤔 I can't think of any issues with this approach but please comment if you think I've not thought of something. Another lesson learned as well. Take more pictures not just of the movement parts and location 😅
    • I dont think mine is. Its an idea to have them all in one place if possible, then a quick screenshot will have them saved. Unless anyone has any other ideas of how to reconnect
    • My email address is in my profile, feel free all to drop me a quick hello.
