I clean the pallet fork with Neophaline (I think it's the same with your 'nafta') using a soft brush. Then I use a piece of Rodico and clean the pivots and the jewels faces.
Be very careful, I managed to make a pallet fork smile at me like a vampire (when I pushed them against Rodico I managed to displace and rotate them by 90 degrees). My advice: apply the Rodico in the horizontal plane, not perpendicular to the pallets.
Bogdan
p.s.:   of course you do not use any kind of alcohol around shellac!
I forgot to mention: you do it quickly - clean the  pallet fork with Neophaline for maximum 15 seconds and then dry with blower. You do the same with the hairspring, also quickly. Mark's method is very nice, the one where you blow air under Neophaline.  Sometimes the spring is fixed to the collet and to the stud with shellac or some sort of glue (white stuff).
Bogdan
I have some Horosolv which is Benzene based - I wondered whether using this as a "one dip" and a burst of hot air to dry off may be a better alternative than the lighter fluid.
Thanks for the info chaps (prieteni)
Vic
Hi Vic, here's much tuppence worth.
For three years I have been using Ronson lighter fuel for initial cleaning to remove the old oil and grease. I wash all parts, including everything to do with the escapement and have never had a problem with dissolved shellac.
This may not be good or recommended practice, but from a practical point it works well for me and has never given me any problems. Like you, this is a hobby and I try to make sensible economies where I can.
I hope this has been of some of some help.
Thanks for that George, your timing is particularly interesting as apparently you are using the "New" version of the Ronson fluid.  Zippo bought them out in 2010 and changed the formula.  It now has 30% naptha content.  I am using cheap Bull brand fluid which according to the can is just Naptha ? Wonder if there are any Chemist types out there to advise.  Anyway, it seems that Zippo lighter fluid is now in Ronson Cans.  The main thing is that you have been using it for 3 years so it has to be the new formula and therefore ok.
Interesting...... I have been using "Swan" lighter fluid, for both the balance and pallets, aerated with a blower and dried on paper also with a blower. This does not leave a film, also Mark has said in one of his vid's that lighter fluid may be used to clean the balance. He didn't mention the pallets, but my theory is that they are only in the fluid for a few seconds and I feel that's safer than the ultrasonic method.
I might be wrong but I think the higher the Naptha content the less film left behind.  But I suppose the question is what is the film and is it really a problem.  I am no purist by any sense of the word so if such a film is not a problem then I would not tend to worry too much but if the film is thick it could gum up the works I suppose.
If Naptha does not leave a film, and, if as I think Zippo and Ronson have now got the same formula then the "film" mwilkes refers to is likely to be the the "light hydrotreated distillate" AKA Kerosene.  This is used to bulk up the lighter fuel and is cheaper than the more highly refined naptha.
I am looking at the Bull tin and the side says: "Contains Solvent Naptha (petroleum light aliph)"  Swan brand also says the same thing and makes a point of putting extra refined on the front of the can.
So my researches seem to indicate the more naptha the better to clean but then I have to think about what George is saying as the Ronson stuff does not affect shellac is that because 70% of the stuff is Kerosene or Parrafin which is basically an oil and it probably does leave a film or coating though I would expect it to be very fine and on a thing like a lever not really a problem and it obviously does the job if Geo has used it for years.
Ok heres my take -  unlike the specialised cleaners which cost considerably more we are talking about loose change so I am going to get some Ronson/Zippo to use when worried about shellac and I will continue to use the Bull/Swan for general stuff. - Unless of course someone provides further info to prove that is a bad idea.
I am now mentally exhausted, is it too early for a drink ? - OK coffee it is.
Cheers,  Vic
Cheers Vic, I'm on my 3rd morning coffee cup! It is 10 am here now.
By the way, if Swan/Bull is also Naptha, why the change to Ronson? I would use them the same. Additives or not it is basically the same stuff - or so I gather from the other posts. The white film is removed with alcohol, I understand, and I wouldn't use that on shellac of course...Just trying to keep a perspective on the budget hobby situation which in my case is a little weird since I spend the money on the expensive stuff most of the time, go figure if that's just another hobby: spending!
Just a thought !?
Do you guys use lighter fluid on ultrasonic cleaner? Also, what do you use for rinsing after?
Copied from a previous post:-
"The first thing I do when I strip a watch is wash the parts in a container with lighter fuel. This gets rid of most of the oily residue before using the ultrasonic bath. If the movement is really gummed up, I will let the parts soak overnight.
I use a small amount of water soluble “carburettor cleaner” dissolved at a ratio of about 1 part cleaner to10 parts water in the ultrasonic bath. I heat this up to about 30C then clean the parts for 3mins. The parts are then rinsed I fairly hot water and rinsed again in alcohol before being gently blow dried on a clean sheet of good quality kitchen towel.
If I am having real difficulties cleaning the parts (dried oil in jewels) I will put the movement in a jar of lighter fuel and hold the jar in the ultrasonic cleaning solution for three minutes at a time until the jewels are clean. The ultrasonic vibrations penetrate the jar and agitate the lighter fuel. DO NOT PUT LIGHTER FUEL DIRECTLY INTO THE ULTRASONIC CLEANER!!
This maybe conflicts with professional cleaning methods, but it works for me."
I do not usually rinse if I use lighter fuel as described above, but I do give the parts a clean in fuel to take the worst off before using the ultrasonic bath.
I bought some brake cleaner & checked the MSDS - it's pure naptha. Leaves things nice and clean and you end up feeling pleasantly woozy after a while...
Also picked up some Bergeon one-dip which is 99% trichloroethylene . Bergeon makes the proud claim that it deliberately leaves a film on the parts as a corrosion inhibitor, which is probably fair enough.
No rinsing required in either case.
Now to find a substitute for epilame...
I am planing on getting a watch cleaning machine but for now what is something I can use to clean my watch movements .i have seen some talk in other post about (lighter fluid ) .are y'all talking about the kind you put in a zippo lighter?
And all so do y'all recommend a ultrasonic cleaner or the one that spins in a jar ?? And Ty for any help you my have on my ?? :)
Hi Daniel,
This is a pretty common topic that comes up quite a bit. I was going to suggest doing a search for it on the forums, but it took me a while  to find the search function! :geek:
Anyway, if you haven't read this post, it might have a few answers for you!
http://www.watchrepairtalk.com/topic/285-ultrasonic-cleaners/?hl=%2Bultrasonic+%2Bcleaner
Regards,
DJW
I plan on just purchasing one of the Elma or L&R solutions specifically for use with watch parts and ultrasonic cleaning. I'll be using the described method of keeping the cleaner and two rinses (to remove the cleaner which might leave a residue or continue doing its "cleaning" too long) in glass jars, put inside the cleaner which is pre-filled with water. Glass is very good at transmitting ultrasonic so that should work just fine. It would then be advisable to avoid any plastic trays/containers since plastic will definitely weaken the ultrasonic power. Perhaps some metal mesh baskets for the really small parts - fishing them out of a jar one by one sounds like one of those irritating tasks ;).
You can make do with cheaper alternatives like lighter fluid, but that stuff is really flammable. I did a bit of research before, so bear this in mind. The flashpoint of Elma WF Pro Cleaner is 30-40 °C, the Elma Suprol rinse is 23-25 °C, and lighter fluid is 4 °C. One of these three belongs nowhere near electronic equipment. Bear in mind that electronic equipment can fail, and the failure may involve a heat source. I've seen reviews for ultrasonic cleaners where the plastic casing has melted or the seals have failed letting the liquid content run out the electric flex inlet! Glass can also fail if exposed to sudden heat or just if it was flawed to start with. It may be safe enough for manual cleaning work in small amounts, but I'd keep it well away from any potential spark source.
What would be a good but chep ultrasonic cleaner .just to get me going for now .i found me two old wrist watch movements to be my frist test dummies lol :p hopeing to get the level 1 tool kit they got for sell at (time zone watch school ) looks like a good one to me .
Yes, the KIT-1-ETA-2750-case, I chose the same movement although I had already most of the tools so the complete kit was out of the question.
I agree completely, if you made it you most wear it! There is a high level of satisfaction and pride in doing so. I do with all the ones I've made and kept!
By the way, I also bought some of the "substitute" movements on line (cheap) so I had a wider range of "experiences" through the class. Funny enough, I've never cased the 2750 and I was seriously thinking about giving it one with the "on-line watch school" wording on it...since they don't give out certificates.
Substitute movements for Level one: UT 6498, UT 6497, ETA 6498-1, ETA 6497-1, ETA 2801 (- , -1 or -2), ETA 2804-2, ST 96, ST 974, ST 969 and TISSOT 245. They come on ebay at good prices...sometimes.
    • this is something I've never quite understood about the some of the Swiss companies. In 1957 Omega was using 9010 for the keyless parts with epilam. there's been a slow migration towards using heavier lubrication's but still typically oils and epilam to keep them in place. When it seems like 9504 works so much better.
    • OK, welcome in the world of alarm clocks... I guess the 4th wheel is dished because it is from another movement. If it was not dishet, then it would not mesh with the pinion of the escape wheel, am I right? The marks of wear on the 4th wheel pinion doesn't corespond to the 3th wheel table position, at list this is what i see on the picts. Calculating the rate is easy - there is a formula - BR = T2 x T3 x T4 x T5 x 2 /(P3 x P4 x P5) where T2 - T5 are the counts of the teeth of the wheels tables, and P3 - P5 are the counts of the pinion leaves. Vibrating the balance is easy - grasp for the hairspring where it should stay in the regulator with tweasers, let the balance hang on the hairspring while the downside staff tip rests on glass surface. Then make the balance oscillate and use timer to measure the time for let say 50 oscillations, or count the oscillations for let say 30 seconds. You must do the free oscillations test to check the balance staff tips and the cone cup bearings for wear. This kind of staffs wear and need resharpening to restore the normal function of the balance.
    • Glue a nut to the barrel lid, insert a bolt, pull, disolve the glue.  Maybe someone will have a better answer.
    • The stress is the force (on the spring) x distance. The maximum stress is at the bottom, and decreases up the arm. That's why they always break at the bottom. I used a round file, then something like 2000 grit to finish. I gave the rest of the arm a quick polish - no need for a perfect finish. Just make sure there are no 'notches' left from cutting/filing. The notches act like the perforations in your toilet paper 🤣
    • It's probably a cardinal rule for watch repair to never get distracted while at the bench. Yesterday, after finishing a tricky mainspring winding/barrel insertion (I didn't have a winder and arbor that fit very well) I mentally shifted down a gear once that hurdle was passed. There were other things going on in the room as I put the barrel and cover into the barrel closer and pressed to get that satisfying snap. But when I took it out I realized I never placed the arbor.  When opening a barrel, we are relying on the arbor to transfer a concentrically-distributed force right where it is needed at the internal center of the lid. However, when that isn't present it's difficult to apply pressure or get leverage considering the recessed position of the lid, the small holes in the barrel and the presence of the mainspring coils. It was a beat-up practice movement so I didn't take a lot of time to think it over and I pushed it out using a short right-angle dental probe placed in from the bottom, but that did leave a bit of a scratch and crease in the thin lid. I had also thought about pulling it using a course-threaded screw with a minor thread diameter smaller than the lid hole and a major diameter larger, but that may have done some damage as well.  Thinking about how this might have been handled had it been a more valuable movement, is there a method using watchmaking or other tools that should extract the lid with the least damage?
