Balance Truing Tool...
64americandeluxe
It looks clean but it's always a risk buying second hand without seeing it first to make sure the tool jaws are in alignment perfectly.
I have purchased a couple of duffers in the past.
The new Bergeon ones look nice but are quite pricy.
