New member from Canada
Mircea
Hello to all!
My name is Mircea and I am thrilled to be a member of the WRT, as I already used many of your advices in my newly discovered hobby, repairing watches! I do know what means watchmaking, but I just started a few months ago in repairing timepieces, so watchmaking is a long way to come yet...
I live in Montreal, Quebec, Canada and I do make my living in a completely different field, ie health services... But I always liked to know how things work and how can they can be repaired, if needed. While a year ago I only had one watch, now I own severals, mainly vintage and of Russian origin. The first watch that I put together was a DIY watch bought from Taiwan in a mail order kit, with a NH35 movement and a very nice diver case, dial and hands. I enjoyed it that much that I started to look on the Internet about various topics on watches and watchmaking, started to seek watchmakers in my area and found one that supplied me with a few broken watches to play with. Well, that was the beginning , changing quartz movements in a few watches and finally dismantling and reassembling a few mechanical ones. With a lot of advice from the internet, and especially WRT (THANK YOU ALL FOR THAT), I succeded in repairing  with very good results two mechanical watches, a Cardinal Russian with a 2609HA movement and an Altantic Worldmaster Swiss with a UN 6300N movement. I am proud to have them working at less than +/- 2s/day precision, good amplitude and very low beat error, and they became a valued part of my watch collection for good. Much more to come...
Well, time is limited so please be patient with me, as I do not know a lot yet, but I am eager to learn and as pasionate as everyone here! Thank you in advance!
See you around in the forum!
  • 2 months later...
