Old mainspring without an inner loop
ifibrin
Surely not, who had worked on the watch must have discarded the broken piece when the repair was not made.
A broken mainspring is easy to diagnose from the outside because the watch winds effortlessly and forever. You would then start work as a repair, not just servicing.
There is still a hole in the mainspring to engage the hook on the arbor, just that there is no loop!
The mainspring broke at the point of maximum stress, typically where curving is tighter. If you inspect the edge you could be able to see signs of fracture instead of a manufacturing cut.
I think we can concur what happened is what jdm has said the spring broke at the most stressed point, a previous repairer has removed the spring and re punched the hole but not bothered to reform the coil as it would require the  spring to be annealed and reformed, a cheap repair that would work untill the spring slipped the arbour and would not re engage. a new mainspring is required to complete the job.
I see what you mean. As soon the mainspring is coiled a little it keeps the hook in the hole. Maybe the recommendation at delivery was not to ever let the watch unwind completely 😏
    • Yup watchie you are entirely on my wavelength with this , you actually said what i was hinting at, what if something happens to mark ? Will someone be able to take over ? Its not that long ago that the forum was down and Mark had to step in and fix it. And you are right a wealth of information that does not exist as a whole anywhere on the planet will be lost. Can that be archived elsewhere?
    • Hopefully if the issue is running costs, Mark would let us know and suggest ways of raising finance. If it's the other issue, which we are skirting around, sites can be passed onto others.   PS because I know you're all interested, I  had a bacon and mushroom sandwich for breakfast.  Hehe.
    • Hello Nosh and welcome to the forum.   Enjoy
    • Hi guys, the question is what is a forum, a place for discussion and passing on information, idle chat and a bit of fun and I for one are the richer for it. When in Hospital last year with the Covid being force fed oxygen and feeling total sh1t and close to the pearly gates a daily look on the forum to see what was going down helped to keep me focused on the job in hand took my mind off the problem for a short while but it was a lifeline for sure. We chat to friends for that is what they become around the world read their posts help where we can post information where we can.  I like @Neverenoughwatches some times think of members past and wonder if they are still at the watches or given up, some drop in for advise and drop out again never to be heard of again. The forum reminds me of Yorkshire hospitality, The door is always open and the kettle on the stove. Long may it continue.   My two bobs worth.
