Hello from Gorgeous Tennessee
AmyV
Hello and welcome to the forum,  There are many books on the subject of Horology, If your interest is in collecting clocks and watches then here is a few starters, Brittans Old Clocks and Watches. History of Clocks and Watches  by , Bruton.  Timepieces by David Christianson. These are but a sample there are many more and also on the repair of clocks and Watches and also tools and their uses. You could probably fill a a room and then some.
Hello again! I have included pictures below to see if anyone would know anything about this bench. We inherited this from someone who worked on watches and clocks. I would love to know an approximate value (USD) if anyone if familiar with this particular one. We can't decide if we want to sell it or keep it in the family. Any help is appreciated!
1 hour ago, AmyV said:
I can't find any type of branding or identifying details.
I think your piece predate by much the time when cabinetry started having brands. Material houses also sold tools and benches, it's logical to suppose they had them made in small batches from the most convenient reputable supplier. And any good local woodworker was supposed to be able to make one based on a drawing or customer requirements.
Welcome to the forum.  Oh what a beautiful workbench!  Just lovely.  I seriously doubt I could speculate how much money you could get from selling it.  I know hand-crafted furniture is not cheap stuff, especially these days.  And I'm sure that bench is worth more than I could afford.  But then, I'm the sort to encourage the owner to keep it rather than sell it.  It looks like something you'd miss later.  And if not used for watches, it would make a fine desk. Thanks for sharing the pictures.
  • 2 months later...
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Here is the fake .pdf for just the FreeCAD base file and 3mf files Modular Movement Holder.pdf Here is the fake pdf for complete set of the new base and ring FreeCAD/3mf files: Modular Movement Holder base and ring v 2.1.pdf However, I'm wondering how often you could use this feature, adding the dial usually increases the OD of the movement, so you would need a new (larger) adapter ring tuned to the OD of the dial and I wouldn't like to grip the dial in any kind of movement holder if It could be avoided for fear of damaging it. Maybe I'm misunderstanding you?
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
