Baumgartner BFG 866 - Friction fitted minute wheel
Baumgartner 866 Barrel friction fitted wheel .pdf
Here is the last instalment of the BFG 866 lessons I wrote.
This lesson shows how to remove the friction fitted minute wheel from the barrel cover, clean, lubricate and adjust the friction setting, so when in 'hand-setting' mode, the hands set correctly without being too sloppy or too tight when turning the crown. Some overlook removing this friction fitted wheel, but as you will see, there is a lot of old grease that doesn't help when left to congeal. Enjoy...
 Share
    • Thank you for the link hippy.  My concern at this point is how to hold the balance in the lathe.  Chucks like on a lathe or a pin vise are good at holding simple cylindrical objects, like drill bits or a cylinder of whatever you're about to cut into. But a balance is a complex surface and I'm having trouble envisioning how exactly it would fit into the lathe chuck.
    • I am guessing this is akin to tuning a piano and is an acquired skill. One thing I saw on a 7750 I worked on was the finger was up high up on the gear. Not all of the finger face was touching the gear. I thought it was bent and I was thinking about bending it down. I decided to leave it alone as it was working. Matt
    • Bulova Seaking Automatic from 1975 I believe. Just restored and serviced this for my next door neighbour. It's 'on test' for the next day. He told me he got it for his tenth wedding anniversary and has been in a drawer for 25 years or so. Going to give it back to him tomorrow evening. I hope he will be pleased to wear it again.
    • Normally you would hold one side of the balance staff in the chuck in your lathe while sharpening the other side with an Arkansas stone . This is the type I used and it's what you need. https://www.hswalsh.com/product/arkansas-stone-type-triangular-size-92mm-x-10mm-ta75
    • Hi everyone, The last two 7750s I've worked on have had the same issue where the watch will stop with the chronograph engaged right when the minute counter is going to roll over. I know this is a common problem and is usually solved by adjusting the minute counter jumper. However adjusting the jumper did not solve the issue. Either I am not oiling something correctly, or there is an issue with the finger on the chronograph wheel on both movements. I can't think what else could be a problem. I have attached a photo of the last movement if anyone has an idea by looking, as the chrono wheel finger is visible. Both adjustments look fine to me, but I would really appreciate any tips someone might give.
