Click mechanism
Smithsmad
1 hour ago, Smithsmad said:
Were would I get a crass click lever for a foreign made Westminster clock and a black screw for it as I do not want to buy a bag of them
Just FYI, we have a section on our friendly forum where it's considered polite for new members to introduce themselves first.
We will need to see photos of the movement. If you can take some nice clear ones photos help a lot.
As jdm has mentioned an intro is the first step on here before asking for help. I hope you enjoy this forum and we can help you.
I have done an introduction. In the members section I am related to the clock maker William baket
I will take it out of the case tommorrow.they look similar to the ones on I few clock mechanisms for locking the barrel cog when winding it up.mr fidalar had got to it and probable lost it.i presumed as it is mass produced the might be a standard part.
Regards
Robin
It may be easier to make one. it's not a complicated shape. You just need a reasonably bit a steel to cut and file to shape and then find a screw and bobs your uncle! (Worst case, nick the screw out of the lower barrel retainer.....but don't tell OH!)
I did think of making one but do not have any material in stock.i have looked for broken clocks to take parts off but no such luck .if I did I would have a go at fixing it.
Regards
Robin
I may have a go at making one then I have had to make parts for valve radios and vintage mowers over the years.i have been looking at various sales sites to see if any one had some in the may come in handy tins that appear at sales and house clearances.
    • Hi. Yes I get it , the slot in the end I’d to allow you to screw the button on whilst holding the pusher shaft. To remove the pusher tube you will need a tool such as the one shown by Richard. I think Ali Express the Chinese Amazon has replicas of the Horotec system for a lot less money, how effective they are not having had to use one. But as you said the way to go is complete removal and replacement, bodging it up will  lead to a repeat failure
    • It does look like it seems to be working again I'm getting emails.
    • One of the things that I've been bothered with lately is timekeeping? For instance a 90-year-old pocket watch what so to timekeeping was it supposed to keep? They publish railroad timekeeping but I don't know how well normal non-railroad watches were supposed to keep time. The reason why the question comes up for me is I spend a lot of time at work adjusting watches to keep really really good time  because I have to please my boss where as when the watch was made I have to wonder what kind timekeeping would've been acceptable. After all they typically didn't have timing machines 100 years ago and they were timing and six positions certainly not for the non-railroad grade watch. On the other hand I do get paid by the hour so maybe I shouldn't be concerned of how much time I Spend trying to make everything keep chronometer timekeeping almost. Citing a Delta of 40 seconds for a 90-year-old watch is quite outstanding.
    • That's an interesting question which I don't think I've seen explained anywhere. But I think the problem will go away just about instantaneously. In other words the  coating is really thin and it should go away almost immediately. So the problem should resolve itself extremely fast.
    • I experienced that different types of shellac and their ages are affected differently by IPA. Sometimes the shellac dissolves in a few seconds and sometimes several minutes are required. Nowadays I never let shellac come into contact with IPA. It's a hotly debated topic here on WRT if you search. Like John, I don't think you need to worry about the weight of the shellac, but instead that it might start rubbing against something. When I learned how to adjust pallet stones, I tried documenting my experiences in this thread. Hopefully, it can help you. I personally don't believe in the idea of abrading the epilame before oiling so I don't think you need to think or worry about it. The only time I've heard anyone mention this is Alex on the YouTube channel Watch Repair Tutorials but actually no one else. I'm not saying it's "wrong" just that I don't think it's necessary or adds anything.
