Afternoon From The Little Welsh Man.
nad
Signed up the other day and received a warm welcome form Mark and recently Geo so it must be time for me to introduce myself.
I’m based in East Anglia in the UK. My other interests include maintaining and restoring my old motor Cycles, and while I still enjoy getting the spanners out, it’s a welcomed break from my occupation in Software Support, I’ve got to the time in life where working in under heated garages is no longer as pleasurable as it once was. Far better to do something similar in the warmth of the kitchen!
Pretty new to watchmaking, I’ve always been interested in mechanical watches though, Since the New Year, I’ve concentrated on vintage Roamer movements. Just like my old bikes, I can look at them and work out how they worked with no major complications and are well enough made to fit back together without distorting things by clumsiness.
With a lot of patience, time and reference to this Forum and especially Marks Videos, I’ve managed to turn the few that I’ve worked on from non runners or start stoppers to movements that run and keep “reasonable time”.
Still early days and looking forward to learning more so there will be a few of the inevitable daft questions from me while I learn.
Thanks.
Nigel
Early Roamers are great watches - I have several - all with good, solid movements. When I started buying them on eBay and in auctions some years ago, they were easy to pick up at reasonable prices, but half-decent ones have risen in price now. The word must have got round!
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Modular Movement Holder.pdf
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
    • Good job, that band matches the watch perfectly.
