Hi I’m new here but love watches, recently found my grandads rally watch, very similar to the first pictured it runs great but Crystal is cracked and scratched so would like to replace it and get wearing it. I currently have it with a watch maker friend who said he is having trouble finding a new Crystal plus the old one appears to be glued down? Believe the serial number is 27675 10578, can anyone give me a part number for Crystal and instructions on how to remove?
Many thanks in advance!
the crystal was not glued at the factory and it would just lift off with a crystal wrench or lift.  First you must remove the bezel ring and I'm sure you will find debris in the underside.
I'll look for the catalog pic of the watch so you can match a new strap.
I don't have the 1978 catalog so not sure about what strap it would have originally come with.  But I would suggest a vintage rally type with the three round holes.
Here is a pic of what I believe is the same sized case bezel so suggest to order what would be a high doom type. Or just keep it as is and just be careful near water.
23 hours ago, JerseyMo said:
no number, you will have to measure the case and the old crystal for dimensions.
good thing is this is a round one so will be much easier to fine a match.
Is it an acceptable practice to replace a Timex crystal with a generic one? I thought I had violated my Telephone Dial Timex when I did that. 🤣
No issue with using a generic crystal if it is the only option.
    • as you took the mainspring out what did it look like? It's amazing how much amplitude you can get if the mainspring actually has the proper shape. last week I was doing a 12 size Hamilton and was very much surprised with the beautiful back curvature the mainspring had. Then the watch had a really nice amplitude the group would be so proud it was 350 until I dropped the lift angle down to 38 that drop the amplitude quite a bit below 300. then with the beautiful back curve it still had really nice amplitude the next day. I really wish all my mainspring's look like this as the watch had beautiful amplitude the next day. So many of the aftermarket pocketwatch Springs I see now do not have anything resembling a back curve may be a slight curve and that's about all. They still work but they just don't work as nice as a properly made spring. then Omega as all sorts of nifty technical documentation unfortunately every single corner is watermarked with where it came from who downloaded it etc. very paranoid company. On the other hand I will snip out images like from the document on recycling a mainspring barrel. for instance here's the section on what your mainspring should look like. water damaged a lot of times means rust was there rust on this watch?
    • I dont understand why a patreon membership would have limited places ??
    • Welcome to the forum, enjoy. It’s highly unlikely you will be able to purchase a new bezel look on eBay for a pulsar watch for repair to find a bezel.
    • just one little minor reminder here this isn't your normal balance wheel.  pages 17 and 18 are what you really want to be looking at. normally studs don't turn but this watch has the etachron system designed for lots of adjustment. Personally I would try to rotate the stud back to where it's supposed to be. If you're lucky you didn't actually bend it at the stud it just looks really bad as the stud has been rotated grossly out of position.. I think things will look a lot better if you put the hairspring back where it's supposed to be by rotating the stud. it's hard to tell if you actually did bend it at the stud or not we won't know until you rotate the stud back more or less where it's supposed to be. Then you want to pay attention to the manual of how to put the hairspring back in the regulator pins because yes they rotate also and they rotated specific directions otherwise bad things will happen to your hairspring. so initially you can open up the regulator as wide as it can go and don't worry about closing it until thing everything is right then you can close them a little bit
