Meteorite Watch
I was allways fascinated by Gems, Minerals and Meteorites.
Then there was a Video on Youtube about a Watch with a Meteorite-Dial.
I want that too...... luckily i could buy a Meteorite-Dial with 31mm Diameter.
But the way the Guy in this Video made it was not acceptable for me,  i dont want to
glue the Dial to the Movement and he did not use the Screws to fix the Movement to the
Holder. So i bought Dial-Feets and glued them to the Dial, for this i made a Fixture to get the
exact Position for the Dial-Feets. So far so good, but the Dial was not flush with the Spacer
(Werkhaltering) of the Movement and the Heigth of the Stem was not exactly in line with the Case
with a Clone of 2824 / ST2130, but it did run.......for two Days.
Time to do it again, but better. I had to mill Pockets for the Dial-Feets about 0.14mm deep and glued them
again, now they are flush. I used a Clone 2826/ST2100 and the Stem fits now ok.
And some Pictures of the Dial, the Fixture (with Teflon Sheet), the Fixture with the Parts to put Pressure to the Dial
(for the Glue), the Dial with the Feets and the finished Watch, bottom and Top.
I hope you like it
Ernst
  • Like 9
Did the seller of that dial say where the meteorite came from (where it was found) ?. I have been polishing and etching a couple of meteorites, you have to etch them to get that structure on them. I suspect this specimen seems to come from Muonionalusta, Sweden.
I like you kept the dial nice and clean which displays the mineral structure in the meteorite, very nice indeed.
  • 1 year later...
    • Thanks, This watch was in a box of old scrape units that a friend gave me. They used to be his late father's who was a watchmaker before the war and then continued later in life. I picked this one out as it looked like it had potential, and I liked the dial, it's been a bit of a learning curve for a beginner but I was determined to get it going. Now I'm on the final lap it feels good. I'm just wondering whether to invest in a decent set of hand placement tools or stick with the cheap Chinese red thing I have, decisions decision 😆
    • An update, for everyone who contributed advice, and for those who come after with a similar problem. Based on the answers received, I decided to work on the face of the hammer first. I used a square degussit stone to guarantee a vertical surface to work against, and ground the face back until it was square across 90% of the depth. I was conscious of the risk of removing too much material.* After I'd got the shape how I wanted it, I polished the surface with lapping film. To cut a long story short, it did the trick and the hammer hasn't slipped off the cam since. Of course, that wasn't the end of my problems. Have a look at this video and tell me what you think is wrong. https://youtu.be/sgAUMIPaw98 The first four attempts show (0 to 34 sec.) the chrono seconds hand jumping forwards, the next two attempts (35 to 47 sec.) seem "normal", then on the seventh attempt (48 to 54 sec.) the seconds hand jumps to 5 sec. and the minute counter jumps to 1. The rest of the video just shows repeats of these three variants. I solved it by rotating the minute counter finger on the chronograph (seconds) runner relative to the cam.  I'd be interested to hear your opinions on that. It seemed to be the right thing to do, but maybe I've introduced another problem I'm not aware of. * What is the correct relationship between the two hammers and cams, by the way? Should both hammers strike the cams exactly at the same time, or is it correct for the minute counter hammer to be a bit behind the seconds hammer? In this picture, I removed the adjusting screw at 1, and the hammers are contacting the cams simultaneously at 3 and 4. I had to turn the screw down tight to achieve this condition after stoning the seconds hammer and replacing the bridge.
    • It was easy enough to pop off. Once I had the cannon pinion hanging on the blades of the stump, I got my #2 tweezers on the gear attached to the staff and levered it down. That way none of the force was on the brass wheel itself.   I reinstalled it and the bridge, and it looks like a small but reasonable amount of end shake. It also spins easily with a blower. It stops quickly, but I think that's due to the large shoulder and about what I'd expect from this wheel.
    • Oh, right. For some reason I was picturing a monocoque case in my head. Good looking watch!
    • Well said Ross. My reason for the thread, i like many of us dont want to lose the forum, such a well knitted group of individuals i feel. But things can happen out of anyone's control. Would be nice to have something in place just in case, if anyone has any ideas please speak up.
