Guidance on slotting a screw
Here is a screw I am making.  It is a setting-lever screw for a Vulcain 120.  The original one suffered rust that consumed the threads.  Dimensions not shown, but the largest OD is about 1.4mm.
I am getting close to parting off and then cutting a slot.
I have a Nicholson slotting file (my dad had everything) that I think will work.  If not, I will have to buy one of those Vallorbe's I see on the Esslinger site.  Or some other ideas you may have.
The question before me...should I soften the metal first?
This is a brand new area for me.  From what I see on the interweb...I just heat it to cherry red and let it cool naturally.
After cutting the slot, heat it again and quench it in oil (2 parts avacado oil, 3 parts saffron oil, 1 part bacon grease...lol...just kidding).
When making any threaded part I make it from soft steel and harden after turning and threading. As you can see the threads are barely formed there, hopefully the die (or screw plate) didn't suffer too much- steel at this hardness can ruin a die.
But, you can certainly file "blue" (hardened and tempered) steel. It's easier to file when soft, but you can do it in the blue state.
Thanks for that wisdom.  When threading, I did not sense any real stress...I was very careful and slow.
I will heat it up and take a shot at making the slot.
Just as nicklsilver says the material usually comes “blue”, it’s been hardened and tempered, but just warm it up with a torch until it is faint red (750-800 degrees) and let it cool off in room temperature, the reverse process is called annealing.
Another thing when making the threads, I think what we see in this example is you turned it to a slightly to small diameter too, if making an M0.9 thread you could turn it to a diameter of 1.1mm -1.2mm (0.2mm – 0.3mm thicker) and thread it from there.
If you don’t have a slot cutter to your lathe then one always can use a small saw with a 0.3mm wide blade on it. Make the slot for the screw when you have annealed the steel.
After you made the part, you harden it again you bring the temperature on the material to above 1400 degrees Celsius, it will have a cherry or bright red color. Cool it off to a temperature below 1000 degrees Celsius in less than a second in water or oil. Since it now is hard and brittle you need to temper it to approximately 288 degrees Celsius, you now will have a useable and a part with a dark blue color again.
If you want the blue color gone you always can polish it away.
Well, the day ended in failure.  I was excited about the early progress, but on the last step I trimmed the screw down too much...too short.
I learned a lot, so I guess the day was not a total bust.
I did lose a watch part in the process.  Complete mystery as to where it went.  Normally, I will find something if I know when I lose it.  This part just showed up missing when I was doing assembly.
Miles to go before I sleep...
Don't worry- I've spent a week+ researching remaking a component for a piece and there's probably the same time  maybe +2 till it works, but they (the customer) are ok with that.
Always do your best, always ask questions.
10 hours ago, LittleWatchShop said:
Why not...I am spending money like a drunken sailor.  What is it???  Just a circular blade on a mandrel?
When coming over to the dark side of watchmaking instead of the watch repair with ready made parts it will cost a bit.
I might have been a bit sloppy and lazy in the text above, it’s what happen when you lay in a hammock and drink G&T. I’m on the mandatory Swedish 5-week vacation right now 😉, but what you need to make a perfectly centered slot in your screwhead is a vertical milling attachment in which you have a disc cutter.
You fasten your screw material in the lathe collet next you adjust the height and depth on the cutter with the slides.
When it is perfectly centered you cut the slot. now you will have a perfect, clean and straight slot worthy a vintage watch 😉 ....
If you decide to use a saw you might consider making a jigg/plate to screw the workpiece into, makes it easier to saw the slot.
Depending on the tresses but I would not have made the screw with blue steel I would just harden when complete.However I have a old chipped screw head slot file that I picked up in a job lot of tools a few years ago but it still cuts fine. To cut the slot accurately I fit the screw into my lathe collet and use the rest for alignment. The pic below is as new.
What is the recommended bar stock to use for such projects?
In the U.S. O-1 (the letter "o", number 1) steel is commonly used for watch parts. Is cheap and easy to find. Easy to work and easy to harden.
Hallelujah!  With extensive searching over a wide are of carpet, I found the missing wheel.  My method involves a very bright light, while wearing 5x magnification and crawling along the floor with my head about 4" from the ground.
I believe what happened was the part fell in my lap.  Then I got up to walk over to the lathe and it fell in the journey.
Since the last nine months, I have completely lost only two parts.  One of this was a click spring (I have many spares) and the other was a date cam wheel that was made of some sort of plastic and broken anyway.
How about letting a strong magnet find the wheel for you, demag the part then.
I did some chronograph pusher rods last week and in the end, I slotted with a fret saw. You won’t get as perfectly straight slots as with a slotting file in my experience, but it’s fine for places where you can’t see the screw head in question.
I did!  But, either 1) I failed to scan the particular area, or 2) it was not ferro.
I suspect #2 because it looked like brass on one side (it was a wheel on the motion works side...an alarm setting wheel with major and minor cogs).
Edited by LittleWatchShop
weren't we just talking about this and a new work bench in the same conversation?
btw-I don't have a lathe yet. someday. however I have been known to repair a screw or two. slots being one of them. I use a jewelers saw (piercing saw) to re-shape the slot and get passed the screwdriver slippage gouges, then finish up with a screw slot file #8(.014") that looks like yours. hey the mangle marks are still there some, but it looks much better and works again. Esslinger and everybody else, including folks on the 'Bay sells the files at outrageous prices. the cheapest I've found go to:
Slotting File 3" Long x 25/64" Wide x .014" Thick | QTE North America, Inc. | QTE North America, Inc. (qtena.com)
if you are able tho, HSL is right on the mark. with the right machinery, correct thickness slitting saw and setup, you'll get the perfect screw slot.
BWCA is closing more sectors. Canada is burning. im near the twin cities and if the wind blows right we get a whiff now and then and it's hazy here. sunsets are incredible tho.
I ordered some 2mm and 4mm 01 steel rods.  My plan is just to practice practice practice!!  Based on just a short time doing this, there will be enough incidences of needing to make screws, so I need to get good at it.
I think I need a modern screw plate just to be sure that I have good thread cutters.
Following up on this screw.  The first two are FUBAR.  Here is a new attempt.  This time I started with 01 steel rod as recommended by @nickelsilver.
I used the screwplate mentioned above.  I am wondering if it is performing well given how old it is and the amount of use it has gotten.  I know for a fact that I abused it when I was a kid playing around in my Dad's shop--he was patient.
Thoughts on these threads?  They are #12 on my screwplate (a little less than 1mm)
I looked around to see what new die I could buy if I wanted to get serious about screws.  It seems that the Bergeon 30010 is the cat's meow.  However, I am still looking for a place that sells it other than ebay.
Just ordered this from Esslinger...looks like the same as yours.
2021-07-23 07_15_53-Screwhead File with Tang for Making Slotted Screw Heads — Mozilla Firefox.png
That thread looks great, especially for a screwplate! Screwplates can be tricky, the older ones both form and cut the thread, so the start diameter can be a matter of trial and error. Good job.
    • I need to see photos of the whole movement before I comment.
    • Hi @Jon, so, from one extreme to another the beat error is 0.1(min.pos) to 0.2(msx.pos), and as you mentioned the rate does up and down dramatically. Also checked the position of the collet, and the collet is not central to the jewel on the balance cock. Balance moves freely, per my understanding.   So, after 24h the ampl. fell down by approx 20 deg, which I would assume is expected. After adjusting the endshake I believe I gained around +10 deg. of balance movement. Which is great, and overall the balance is not at 220'ish deg.   What I did next, some might think is non-orthodox, but was wort a try. I too the mainspring out, checked again for endshake and if the pin moves freely, and cleaned everything. Usually when installing the mainspring I would use some barrel grease on the barrel walls, install the spring and put a 2-3 drops of D-5 oil on top of the wounded spring and in the places where the arbor sits. This time I took the spring and applied a ultra this coat of Molykote Dx paste on the whole spring, before installing it in to the barrel, and added some oil to the arbor as usual.  The result improved, at a full wound the balance produces about 230-237 deg. @JohnR725 I'm getting closer to 300 😃   What I am noticing, there is a fluctuation in amplitude. With time it would rise and drop about total 8-10 deg in an interval about 2 minutes. I assumed this ruled out the power transfer from the barrel itself. So I took the gear train out, cleaned and lubed.
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Here is the fake .pdf for just the FreeCAD base file and 3mf files Modular Movement Holder.pdf Here is the fake pdf for complete set of the new base and ring FreeCAD/3mf files: Modular Movement Holder base and ring v 2.1.pdf However, I'm wondering how often you could use this feature, adding the dial usually increases the OD of the movement, so you would need a new (larger) adapter ring tuned to the OD of the dial and I wouldn't like to grip the dial in any kind of movement holder if It could be avoided for fear of damaging it. Maybe I'm misunderstanding you?
