1951 Pobeda running very fast
Hi all,
I bought an old Russian Pobeda watch about a year ago. It has been running great for a year, maybe 20 seconds slow per day. Well, starting yesterday th in watch just started running super fast. I checked it against a digital clock and it's running a full 60 seconds in 50 reference seconds. So every 5 minutes the watch is running 1 minute fast. In an hour the watch is running 12 minutes fast.
So, what is the most likely culprit for this sudden, significant increase in speed? Thanks.
AR
having a timing machine would be nice?
have you tried to demagnetized the watch? Oftentimes magnetic fields are a problem. then have view taken the back off and looked at the watch is the hairspring stuck together either because it's magnetized or lubrication or something sticky is holding the coils together. is the hairspring where it's supposed to be? Sometimes a watch gets bumped the hairspring will come out of the regulator pins or this basically hairspring isn't where it's supposed to be this is where guessing what the problem is is nice but physically looking at the balance wheel is better.
 Most likely causes are; the last circle of the hairspring coil has got stuck behind the stud or hairspring fauling itself or sticking as which John explained.
Coils should be concentric, level, flat and breath evenly.
Hairspring issues can happen even if a wstch doesn't recieve a shock, simply a screw can come off and get into hairspring.
Its got to do with hairspring,   Remove the back the problem will be starring at you.
Good luck pal.
1. I notice that the stud carrier and regulator on Russian watches are usually a loose fit, it could have been bumped and the timing would be off.
2. A lot of Russian watches have an overcoil.. good for timekeeping but the hairsping needs to be aligned properly in the flat.
Anilv
Hi guys. I have uploaded two images with the back off, the second being a close up.  I didnt notice any foreign objects in the hairspring, but I haven't taken it out yet. In the close up, I did notice a horizontal screw at 9 o'clock was backed out more than I would have guessed it should be ( I guess that's the hairspring stud screw). Sorry guys, I'm just getting into mechanical watches, so I'm not extremely conversant yet.
If you take a close up shot with the hairspring in the center focus you should be able to see the hairspring has been twisted. One inner coil has ended up in the regulator pins which would explain the high beat in the watch, but an arrangement like tis makes it impossible to regulate so you have to take the balance cock off and sort the hairspring out.
Perhaps it gets loose just by lifting the balance cock up.
A picture like tis is better when showing the hairspring.
 I agree with HSL, you should remove the cock with balance attached, the hairspring might just jump back to the coil it was, since you haven't touched the coil, at worst you might have to remove the H/S to sort out.
Could you show a magnified picture of the coil, just detach the balance and cock to show the coil.
Regs
Joe
Not sure if I agree with this, we certainly need a better close up shot of the H/S for clarity.
This is a Breguet over-coil H/S so regulator is going to be inboard of the radius of the H/S with the over-coil moving back inwards to go through the regulator pins.
It is difficult to tell from the pic, but I'm wondering if the watch has been jolted causing the over-coil to jump out of the regulator pins (there's no boot on these to retain the H/S) and the over-coil has ended up pressed against the inboard side of the inner regulator pin rather than between the pins. Trying to follow the trajectory of the terminal curve on the supplied pics is very hard but it looks as though it may be heading too far inwards. The H/S also looks as though it is slightly displaced towards 5 o'clock, which would also result from this. Am happy to be wrong as the pics do make it very difficult to draw a conclusion.
I agree we definitely need more pictures because it doesn't quite make sense of it looks bad and there's an over coil something definitely looks wrong.
Then ideally the movement should come out of the case and that's going to be interesting? You going to have to take the stem out and because the way the case screws are in I'm guessing the movement probably comes out through the front. once the movements output the stem and crown back in and get us a picture sideways into the movement.
Ok, thanks for the input. One thing to clarify, this picture was taken with the movement in motion. This may account for the HS appearing to be displaced. I'm going on vacation away from home today, so I won't be able to take any pictures or disassemble the movement.
    • Got another one today! It took 10 weeks, but finally arrived. Fairly complete but I added the pivot guage. The burnisher and bow came with the tool. The case is a bit rough and the tool pretty dirty, but trying to decide how much I want to restore.
    • OK, so long story short, I'm working my way through Mark's courses using a "Sea-gul ST36" (or ST3600 from some vendors) AKA an ETA 6497 clone. as a practice piece.  I've had it fully appart and cleaned it, and have had it fully back together an "running", but only briefly as my oil hadn't arrived at the time.  In the course of that work, I saw no markings on the movement that would tell me if it was a true Sea-gul or just a clone of their clone of the original ETA movement. Well, fast forward to this weekend, when my oils arrived in my mailbox and I sat down to try my hand at oiling.  Everything was going swimmingly until I got to the shock setting on the top of the balance cock.  I was able to open the lyre spring without issue, but in attempting to swing the open to access the cap jewel and chaton, I apparently accidentally pressed the launch button as I sent the lyre spring into low earth orbit.  Like most things that make into such orbits it came back down at a place not too far from where it started, but of course that also means that it is no longer in the setting. So my task is now to get said spring back into setting.  What I have read so far tells me that I seem to have two options: Another thread here seems to indicate that the spring came out without taking the balance cock apart, therefore it should go back without the need for that procedure.  That seems a bit pie in the sky for me, but the posts in said thread also gave some high level information about how to get the spring back in (putting it at an angle to the channel cut in the cock and canted so that the tabs fit in the slots, followed by some "wiggling" to get it turned around the right direction.)  I've tried this a couple of times, which have lead to more trips to low earth orbit, but with successful recovery of the orbital vehicle after each trip.  This thread also suggests that what I did to cause the initial launch was to push the spring "back" with more pressure on one side than the other, which put it under tension and caused it to deform out the slot either on one side or at the end (where there is apparently no "back stop".) The other option appears to be varying degrees of disassembly of the balance cock.  Some things I've read suggest that the whole shock setting needs to come out, while other threads here suggest that I only need to remove the regulator arm and the arm carrying the balance stud.  After the last trip the spring made, this is seeming like a better option, but I'm super short on details on how to do what needs to be done.  if I am following correctly: I need to loose the balance spring stud screw so the stud is not held in the arm. I need to somehow disengage the balance spring from the regulator (all the regulators I've seen in videos look nothing like what I see on the balance cock I have.)  What I've seen on the interwebs is a couple of "pins" that the spring passes through.  What I see on my assembly is something that looks more like a single pin with a "V" shaped notch cut in the bottom of it.  The spring is secured in that notch with something that I guessed was glue, Posts here suggest that on some of these movements glue is in fact used.  So I'm trying to figure out how to tell, how to soften dissolve it (I'm guessing IPA or acetone) and how to put it back when I'm done (superglue?  UV glue?) With the spring detached from the cock, I've read that the regulator and stud carrier are basically glorified C clamps around the shock setting and that one removes them by slipping a razor blade under one side of each and prizing them up.  I assume that they go back in the reverse manner like another C clamp, but that again is only a guess.  The place I got this information from seemed to leave that bit out. Once I have one or both arms off the shock setting the above mentioned post seemed to indicate that I could just slide the spring back in the slot, though again, I'm interpolating between the lines I read.  The alternative that I've seen demonstrated on high end movements on Youtube is to remove the entire shock setting and to replace the spring from "underneath" rotating the setting so that spring basically falls into place. I'm not anxious to try this method, as I don't have a jeweling tool to put the shock setting back into place.  That not to mention that the professional watch maker who did the demonstration described "fiddly work." So at the end of the day I'm looking for a little guidance on which pathway to follow, or if I've missed something obvious, a new direction to follow.  If this is a repair that just need to wait until my skills improve I'm totally good with that, I can get another of these movements in relatively short order, I just don't want to treat this one as disposable, and I do want to make an honest effort at fixing it and learning from this experience. Thank you in advance for reading my ramblings and for any suggestions that you might have!
    • All the best, family always comes first, and I believe you have made the right call that you mother deserves your full attention. However, when you need a little outside distraction the guys here will always be available for some banter or a heated discussion on lubrication 🤣.
    • Wire for what? if it's steel then only certain types of steel can be hardened ie high carbon steels: "Mild steel doesn't harden very well. It doesn't have enough carbon. Get something like O1, silver steel or if you want to go full watchmaker, then Sandvik 20AP". Source
    • I'm wondering if there's any specific type of wire I should get for hardening? I would assume it doesn't matter as long as the wire doesn't melt before it is at temp.
