Rack and Snail
RogerH
Hi all, I have a Smiths Mantle clock on the bench. all cleaned and running well but I'm struggling with the set up of the hour train rack. as far as I can see it's set up correctly. the rack drops onto the snail ok - not in the middle but it looks to be at the point it was originally at and is consistent through all the hours. However, it won't chime past 6. the picture shows the snail at 7 o'clock but when it runs it will only chime 4 times. I'm at a lost trying to figure out how the rack works as there are 20 teeth. as the bean cam rotates it seems to move the rack past two teeth at a time. given the amount of teeth I assume this is correct to a certain extent but I can't work out what the ratio should be......or could it be something else I'm missing?
Looks to me as if the snail needs to be moved 1 tooth on, the rack is only just at the 7. Have you got the warning right? the gathering pallet should not be engaging the rack at that precise time, it should be free to drop onto the snail. The gathering pallet should engage one tooth at a time.
Thanks OH, yes, the warning is ok and engages correctly. the rack drops ok but I'll move it over one tooth so it falls in the middle and see what happens. Interesting that it should be one tooth at a time, why twenty teeth and not twelve?
I don't know if anyone has answered this for you when you have the snail on be sure it is engaged to the cog that sits next to it with a circling on let the rack fall onto the snail. The little arm that comes off the rack must sit halfway between the the rise and next fall on the snail cam. It will automatically fall on the right hour from there.. let me know if you need any help. Really great movement the Smiths clock.. eventually bought out by Enfield...cheers..
so, there are a few good videos out there and I have a couple of books all which pretty much say the same thing - although you do have to be wary of some YouTube stuff as it often shows some dodgy looking practices! however, I think the problem, in part lies with the rack hook. I've attached a picture to show how it is just out of alignment and falling the wrong side of the teeth. There doesn't appear to be any signs of damage or being out of shape but a small adjustment of the pin ensures it falls into the correct tooth and chimes away merrily. I'll keep it on test and see what happens. it seems odd to me that this should happen though and I'm concerned I may be missing something else - bending a pin doesn't seem right but I can't see any other reason - it may have been caught during cleaning perhaps? does anyone else have experience of this sort of thing? am I being too cautious or do old clocks need a bit of pulling about every now and then?
From what you have said and shown I noticed that the part has at some point been bent which could play a part in why it isn't engaging correctly, which means you will most likely have to adjust. I agree many videos on youtube are terrible, the video one from someone who goes by the name Scottie and he is a joke to watch.
14 minutes ago, clockboy said:
I presume you followed OH advice by moving the snail one tooth. When the the rack drops does it drop to allow enough chimes. If you could please send a vid of it operating.
Hi Clockboy, yes, I always follow OH advice...who doesn't! I've moved the snail along so the rack falls in the middle although, tbf, it didn't seem to make much difference and certainly didn't solve my issue. I think his latest tip about the arm may be the solution. I'll look it at again tonight and run it over the weekend and see what happens.
I've seen Smiths Enfield clocks before but this is the first Smith only - so I'm guessing it's an earlier version? it's certainly a nice movement. Well made and with main spring barrels that can be removed without having to take the mech apart....always a good sign!
    • This is a very valid point and a subtlety that I was unaware of until fairly recently, learning all the time, the video below explains this point well:
    • You don't have to use his special tester. Any good multimeter would work.
    • Yes, it looks like GT Revue 30. Doctor, You can not replace escape wheel by the dimensions You listed. One needs to know much more things like number of leaves of the pinion and it's diameter, the position in high of the table and the pinion, the hight between the pivots, the exact pivots diameter... And then, even if suitable wheel is found, one will need to know how to adjust the pallets position correctly. Restoring antique movements is something different than replacing parts. In older movements parts are not interchangeable, this means spare parts do not exist. Here the case is different, but still escapement adjustment will be needed if a wheel from a donor is found. So may be it will be easier to restore the donor for You...Restoring antique movements usually means making of the parts needed and this requires knowlage and working on lathes skill. In this case repivoting of the wheel is the natural solution, but there is a long way that one must walk untill getting ready for such work.
    • I was looking at Essence of Renata, a chemical used a lot for cleaning hairsprings: "Specially prepared solution for degreasing watch and instrument components. Indispensable for degreasing hairsprings." Looking at the MSDS you can see this is just pure n-Heptane, so could be an option for those who don't want to use the chlorocarbons or hexane?     HF6013 - Horological Essence COSHH Safety Data Sheet Horological Essence_0.pdf
