Certina 13-20 Walkthrough
My first week of vacation I got hurt in my back playing superman while lifting 24-wheelers with one arm. Unfortunately, I’m not 20 any more so I had to limp for a week bent like a U after the show ended.
So today I felt like I could make a strong comeback so I wanted to put me to a test, in doing that I whipped out the smallest woman’s watch from the man cave I could find and off I went. What better way to spend a sunday off.
This walkthrough will not show any disassembly since I also only had the smallest camera I could find at hand. I fast forward until the point everything been properly cleaned and I just have to magically piece everything together.
To save place at the site I compiled everything into one PDF enjoy…     Cetina 13-20 Build Walkthrough.pdf
Here we can see the movement beside its bigger brother.
  • Thanks 2
8 hours ago, Nucejoe said:
Is the big brother a Chrono grade and if not what makes it a good grade luxury watch.
They are just chronograde for so long, don't know of so many sending them back for re-certification.
So what do owners want recertification for? are not all in-house Certinas Chronograde? or we like certification to verify our watch still performs up to Chronograde?  or that it is not a fake.
After you serviced a chronometer graded watch and even perhaps switched parts in it you can’t guarantee it performs after the specifications, of course the text will be there but otherwise it isn’t the same watch as in the beginning. Very few workshops have the ability to test a watch according to the COSC standard. Even fewer hobbyists.
Rolex might send some chrono-grade watches back, but no one hardly would do that with a Certina for a fraction of the price.
 Knowing you to be a Certina enthusiast and I owe Rogart63, I have been keeping an eye open for Certina for sale on domestic sites, there is a 919-1 Certina, square case , with imperfect dial paint, decent price, you pay. ha ha🤠
 I wonder if a regulare balance complete for 919-1 exists and could have been fittef in this piece. Unfortunate my tablet wont cooperate to send you a picture of it.
Regs Joe
22 minutes ago, Nucejoe said:
you pay. ha ha🤠
lol, yes Rogart63 lives just around the corner in the town below mine.
I already have a couple of nice 919-1, my favourite sits in a Argonaut 285..
Great and entertaining walkthrough. Thanks!
"Either the summer heat or the 26 beers made me sloppy but I revers and fast forward and by magic
I’m back in track."
Definitely the "summer heat" being the culprit here! 😆
Just out of curiosity, what would you say is the diameter of the smallest jewel in this movement? The smallest pusher in my Seitz jeweling tool set is 0.65 mm and I guess that would be way too wide if you needed to adjust end shake.
Took a measurement and the smallest jewel on this one actually is seven hundred of a millimeter (0.7mm).
I guess one can’t have them too small of practical reasons since you need a hole for the pivot, an oil cup and some space in the sides. The tricky part is to see how to lubricate without making a mess around the whole jewel. The ones on the train is slightly larger.
So no problems adjusting the end shake...
Thanks, that's good to know (I have never serviced a ladies watch movement)! So, obviously the jewels aren't sized in proportion to the rest of the movement. I replaced a cracked pallet fork jewel (80/10) on the main plate of a Vostok 2414 yesterday, and it was pretty fiddly. A 0.8 mm diameter doesn't sound all that small but it sure feels small to handle. A 0.7 mm jewel would probably feel twice as tiny.
Oh BTW, that oiling looks absolutely perfect! Beautiful!
Edited by VWatchie
    • These are all American movements (with the exception of the "Rubis"), and are all almost certainly "negative set" which means the stem is part of the case. So it's normal that they are all missing- they are with their cases. You will need male square bench keys to wind/disarm them. Vintagewatchstraps has a great writeup on the different systems. But basically, any American "x" size movement will fit any case for that size, possibly with some adjusting of the stem position. With Swiss movements, there is some interchangeability between calibers, usually within the same maker's range, but not really overall- there are thousands of different stems out there.
    • Hi, I'm very new to watchmaking and this is my first time posting here.  I've bought a lot of 10 vintage pocket watches size 0s from e-bay and just got them today.  Most of the balance wheels sprung quite freely and thus seemed like a worthy endeavor as a first batch for exploration.  I've just realized that none of them have any winding stems. Is there any way I could source appropriate winding stems for the movements? There seems to be assortments of various stems selling in bulk on aliexpress, but would any of them fit?  I've read on other threads that some people lathe their own stems (which is waaaay out of my current skill set, which is pretty much nil). Others say that you 'just have to try a few and see if they fit'. I would much appreciate any advice for this matter. Thanks!
    • Nice work.  In the last year, I have been servicing Accutron 218s.  I have the official Accutron hoder that provides electrical contact to the movement.  It is a pretty clever design.  There is a cut in the ring of the holder (shaped like a "C").  When in relaxed state, the holder is slightly smaller than the watch movement.  You spread the cut slightly and drop the movement in and release.  Very clean.  I have made 3D versions of this setup.  Have not explored using it generally for other movements.
    • Double Oooooo   Removal tool? Dreamed of one of these. However, Kalle on Chronoglide showed everyone my system with the pegwood. Worked a treat. Felt so chuffed to be mentioned. https://www.youtube.com/watch?v=tTFrXjiyGKc 46:40 for the wheel removal. Mentions me at 50:00 and does the removal with the pegwood. Felt like my 15 minutes of fame.
    • Sirius. Thank you for helping others with that information. This is why this forum is so good.
