Rolex bracelet repair
My neighbor asked me to look at his Rolex.  His bracelet broke a long time ago, so he bought another Rolex rather than have the bracelet repaired.
You can see in these pictures that there is stress on the metal that wraps around the pin.
Will the metal stand the stress if I bend it back around the pen...or will it be too risky?
1 hour ago, watchweasol said:
Probably not as the metal is already fatigued and any re forming weill over stress the metal. It may hold for a while but will break again.  A bit poor for that class of watch though.
Kinda what I figured as well.  Here is a possible solution that appears very inexpensive.  Pretty sure it is the correct piece.
Your jeweler can fix this.
 Use a torch  to bring the stressed part to a glow, it will bend with ease and wont break then. Some folks solder more metal onto the streesed seam,  then file to shape and polish.
It might eventually break again as weasol says.
Since it’s a Rolex, and what looks like probably quite a fancy one, I’d get a replacement link, or buy a European or USA-made link and adapt it to fit and re-finish to match.
That link is toast, you should change that link there are lots of them out there.
Some curiosity about this one 62523-H14 F3, the clasp tells a story to F3 says it was made around 1981.  It should have stainless and 14 carat gold links. The broken bracelet matches the Rolex in the picture. You need two fittings too if they gone lost when someone changed the bracelet.
You can change that link yourself without any problems and the best thing is the bay is filled with them, would be a shame to not fix it properly. Just push out the pin holding it in place a 10-minute fix.
Edited by HSL
I received the end piece that I found on Ebay.  You can see in the picture after I attached it.  Notice that the end piece I bought was meant for the OTHER bracelet section--as such it is too wide.
I only paid $120 for this, so not much invested so far.
I am thinking of just cutting it and polishing out my cut.  Notice that the replacement piece uses heavier gauge metal.  This is a good thing as long as it fits once the buckle is closed.
Three factors to consider: 1) the bracelet is currently useless unless I do something, 2) the end piece I bought is only a minimal investment, and 3) if I ruin the end piece that I bought, the rest of the bracelet remains pure.
Comments???
I’m not sure if you would be able to simply cut the width of the link down. If you look at the original part then I think the narrow section is longer than the corresponding link on the other side. There is a flat on the link. It may be ok if you simply cut the link down, but you would need to check that it interfaces correctly when the bracelet is closed.
Also, in case you don’t know already, the riveted pins are removable - don’t attempt to open any links to press them around the riveted pin - just buy a new pin. I repaired a badly damaged Rolex sub bracelet last week.
    • Just a note for those who come searching for information on this topic in the future.  I did eventually find the Mark's video on how to replace these springs, as someone observed, he does in fact make the replacement look easy.  (It actually is relatively easy once you have the knack of it.) If you're enrolled in one of Mark's online courses, the demonstration of how to replace this spring is in the Bonus Videos section of his course site, and is called "C2B1 – Sea-Gull Style Shock Springs".
    • If the metal was twice as thick, it wouldn't snap so easily.  The thickness is governed by the space available so you can't use thicker metal.  If you glued two pieces together, the likelihood of snapping would be reduced.  That's my theory anyway, could be wrong.
    • there are various approaches to learning watch repair. A lot of people want to jump right in and every single watches something to be repaired restored. But other times like this it's disposable it's here for you to learn and when you're through learning you throw it away. yes you definitely should try this you have a learning movement you need to learn and the best way to learn is by doing something.
    • Sorry, the friction will be so great that the wheel will barely turn, if the movement will start at all, the amplitude will be verry lo.
    • If I can’t re-pivot the wheel, the logical thing to do is to descend the pivot hole.  Plan is to either stick a suitably sized hole jewel (from a barrel bridge or something) or fashion a blob of epoxy on the underside of the escape wheel cock so the wheel sits on its one pivot on the base plate and the staff with the broken off pivot (which I’ll polish as best as I can) becomes the upper pivot. As long as it doesn’t foul the 4th wheel it should work? I know it’s a bodge job, and if this were a rare movement, or belonged to someone else I would not do this. I’m just interested to see if I can get the thing to run.
