Fixing Old Coin Silver S18 Case
Working on an 1885 Illinois Pocket Watch and it’s case back does not close properly. I think it was pulled back beyond spec at some time in its 150 years. Does anyone have any advice on how to get the lid back into place. Here are the pictures. Thanks
JD
Some of these pocket watch cases have springs fitted inside the case, you press down on the button and they open, the spring might be also at fault, but normally it's a strain on the silver hinge or even a split. A job for a silversmith.
Likely better to source a new case as repairing This case is beyond my abilities to repair at the moment. What I don’t want to do is get too curious and become a silver smith:). I’ll look at it a bit closer.
I'm with clockboy. Try a little soldering! Tinker...think. fix it! You're a retired engineer. Hey if you can cut out a paper balance wheel template to test a balance staff, you can hammer and solder a watch case hinge😁👍
I used a an old spring pin once to fix a hinge. It worked. I'm no silversmith either..
If this was my watch, no issue. The problem is that it is not and I would want to practice a lot before attempting this repair.
    • this is something I've never quite understood about the some of the Swiss companies. In 1957 Omega was using 9010 for the keyless parts with epilam. there's been a slow migration towards using heavier lubrication's but still typically oils and epilam to keep them in place. When it seems like 9504 works so much better.
    • OK, welcome in the world of alarm clocks... I guess the 4th wheel is dished because it is from another movement. If it was not dishet, then it would not mesh with the pinion of the escape wheel, am I right? The marks of wear on the 4th wheel pinion doesn't corespond to the 3th wheel table position, at list this is what i see on the picts. Calculating the rate is easy - there is a formula - BR = T2 x T3 x T4 x T5 x 2 /(P3 x P4 x P5) where T2 - T5 are the counts of the teeth of the wheels tables, and P3 - P5 are the counts of the pinion leaves. Vibrating the balance is easy - grasp for the hairspring where it should stay in the regulator with tweasers, let the balance hang on the hairspring while the downside staff tip rests on glass surface. Then make the balance oscillate and use timer to measure the time for let say 50 oscillations, or count the oscillations for let say 30 seconds. You must do the free oscillations test to check the balance staff tips and the cone cup bearings for wear. This kind of staffs wear and need resharpening to restore the normal function of the balance.
    • Glue a nut to the barrel lid, insert a bolt, pull, disolve the glue.  Maybe someone will have a better answer.
