Hello from Maryland!
Hello all.  My name is John and I live in Maryland, not too far outside Baltimore.  My obsession with this hobby started about three years ago, after watching Mark's video on how to make your own watch from parts.  I built the watch shown in the picture below, which is powered by a Sellita SW210 and is a great little timekeeper.  Despite my difficulty with fitting the seconds hand, I was bitten by the bug and then built a handful of watches for friends and family of varying designs.  I've recently signed up for Mark's online watch repair course and have just completed level two, servicing a Seagull ST36 in the process.
I'm looking forward to getting to know the community here!
On 6/23/2021 at 8:22 AM, Michael1962 said:
Have you got any photos of the other watches that you built?
The second watch I built is a pilot's watch based on a Seagull ST36.  The lume on this dial is fantastic.
The next watch I built is based on a skeletonized ST36.  This one was a real challenge but came out great.  The case is the smallest I've seen for a 6497 at 41mm.  It doesn't use a movement ring.  Instead, the movement is held in place by careful adjustment of the height of the case clamp screws, so that they just touch the caseback when it is screwed down.  I still have nightmares about this case.  I ended up 3D printing a spacer ring to fit between the caseback and those screws.
Guess how many times the winding pinion fell out when I removed the stem with the watch upside down on my casing cushion?  🙂
I then built a few other watches using Otto Frei's 36mm 2824 case.  Here's one with an open heart dial that uses a reclaimed Hamilton movement:
    • That would be something! Which brings me back to;
    • you think you're going to sleep tonight you're not, you're going to ponder the question of what makes you think those of the right parts?
    • Does anyone knows what size case a need for a dial diameter 20.60mm?
    • Sounds like the story with my Rolex. Poor (expensive) job done by an official Rolex dealer with an "in-house" watchmaker, hence I learned watchrepair and did the servicing myself. Same story as I learned with the Omega 861, again poor job by an "in-house" watchmaker by an official Omega dealer. Once your watch goes through that back-door, you have no idea what is going to happening to it 🫣   Quite nice that they sent back the parts which had been replaced !
    • yes that's definitely not right at all. I have a picture one of my friends has a Omega coaxial there was having issues to lose asking me where he should send it. As that's a specialty watch I suggested the service center. When he got it back he sent me a picture so the replace the dial as you can see the hands the mainspring barrel and I think the price was really quite decent considering all the stuff they can replace. So I do know they do change the barrels but the other person I worked at the service center when I would ask questions and unfortunately I can't remember all the answers. I think a lot of the changing a parts is at the discretion of the watchmaker. Plus I don't know enough about the chronographs and whether that would be considered a vintage watch? I take some of the vintage watches may have been sent directly to Switzerland or another service center. Obviously with a watch like the one down below they probably have a infinite supply of parts is its relatively modern vintage stuff becomes more interesting even the watch companies don't have necessarily infinite supply of parts. But no matter what the watch shouldn't disintegrated six months that's definitely an issue.
