Needing Watch Bezel
1 hour ago, MarkosAurelius said:
But why not for these types?
Probably because these brands are not popular, I for example have never heard of them.
Anyway, there is no secret place for parts, everyone does the same searches whic reveals the same sellers. If you are OK with plastic you can have these 3D printed as a service.
I hadn't either  until I got one in a watch lot from Etsy i purchased and about fell out of my chair when I saw what some really junky ones were going for on Ebay.  Problem is..the bezel is so old It chipped when removing it. THere is a stainless steel band that runssss just inside it on the back.  You know what gets me is they aren't much different than what's been made for Vostok, Seiko, or even Rolex.  I just nees some dimensions of those brands as I could narrow down a fit with  them.   Any diver watch has some accruting value to it.  Thanks for the info. These sellers of bezels seem to make a huge thing out of them. And some of them are really too expensive.
I want them to be original  Black plastic.  Can a 3D printer put the printing of numbers and countries on the face of them as well?  Where is this service?  3D printing did cross my mind. I considered scraping up some cash for one .
Thanks again!
Edited by MarkosAurelius
Have you checked if these are pin lever, or manual wind movements, as there is not much objecti value and interest in these. Also, for a correct restoration the mov.t must be serviced also, which significantly increase cost.
Yes, or can leave embossed for some painting.
Anywhere there is someone is willing to make his printer work for others. They may advertise on online marketplaces, etc. However if there is no ready model, one will have to be adapted or created in CAD. That is the work that takes up more human time and skill, and would cost more.
I do lots of 3D printing.  I don't think you would be happy with the result.  There are higher resolution printers than mine that might be able to pull it off, but I doubt it.
Based on my limited experience, a basic printer should do for making a no pretenses rotating bezel for an economical watch that originally had a plastic one. The top face would have to be sanded, but if it had embossed numbers these could be filled with contrasting paint. The knurled border should be no problem.
Perhaps, but not with embossing and numbers and such.  I have a Lulzbot Mini.  Been printing for about four years.  I love it, but if I ever try to do something small and precise...I am disappointed.  Maybe it is just me.
    • @JohnR725 that's very helpful.  I appreciate the time you took to give those instructions and post the pictures.  below is a picture of my staff, which looks identical to the ones you posted.  The approx measurements I got are: .772 on the left part of the staff; .715 on the right side of the hub; the hub is 1.107; and the overall length (minus the broken pivot) is 5.248; which seem to line up with the measurements you posted.  I didn't think to measure the pivot, which I'll do if there's enough of one left on the staff.  Thanks again.
    • Thank you to both of you!  I've been somewhat derailed by this quandary for a couple of days now. I am guessing that the point of the wider tweezers is to support the whole spring at the same time in an effort to prevent it going under tension... I have already discovered the Zen of a clutter free space, and trying to keep my work well away from the edge, however the most terrifying of the flights wasn't so short, I had my work in the middle of the table and nothing else around.  That particular launch was towards me.  I distinctly recall feeling the spring hit my left hand as it escaped.  I only found it by dumb luck, on the floor, between the legs of my chair.  I need to order a pack of replacements just in case.  I think I recall a thread discussing where to find them, and the differences between the clones and the authentic ETA ones, pointing out that they're not interchangeable (the clones being longer IIRC).  Now I just have to find that thread again.  What I haven't mastered is the zen of the search function here.  I'm sure I"ll get that down eventually. So this is similar to, but different from one of the posts I had found in my original searches (or maybe I'm just hallucinating, I can't find the post I thought I remember).  The bits about the corner filled in a gap in what I'd read before.  At least I have a more clear picture in my head about what needs to happen now.  Yes, I've learned about how touchy these springs are.  What I'm not sure I have a good grasp on is the understanding of what causes the spring to flex, other than to say "the slightest little touch"  I think I'm going to try a small bit of Rodico to position the spring next time.
    • I think it's stamped on the inside cover. 309 I think.
    • Hi all, needing a little help. I have an old Casio AQ-321G, but have no idea what battery it takes. I've looked around online, but cannot see anything... I see a 309 stamped on the case back, could this be it....? Can you please help, below are some pictures:
    • The radial teeth are for hte seconds register, and the other (which is simple and doesn' take away significant torque from the train) for the minutes register.
