Needing Watch Bezel
1 hour ago, MarkosAurelius said:
But why not for these types?
Probably because these brands are not popular, I for example have never heard of them.
Anyway, there is no secret place for parts, everyone does the same searches whic reveals the same sellers. If you are OK with plastic you can have these 3D printed as a service.
I hadn't either  until I got one in a watch lot from Etsy i purchased and about fell out of my chair when I saw what some really junky ones were going for on Ebay.  Problem is..the bezel is so old It chipped when removing it. THere is a stainless steel band that runssss just inside it on the back.  You know what gets me is they aren't much different than what's been made for Vostok, Seiko, or even Rolex.  I just nees some dimensions of those brands as I could narrow down a fit with  them.   Any diver watch has some accruting value to it.  Thanks for the info. These sellers of bezels seem to make a huge thing out of them. And some of them are really too expensive.
I want them to be original  Black plastic.  Can a 3D printer put the printing of numbers and countries on the face of them as well?  Where is this service?  3D printing did cross my mind. I considered scraping up some cash for one .
Thanks again!
Edited by MarkosAurelius
Have you checked if these are pin lever, or manual wind movements, as there is not much objecti value and interest in these. Also, for a correct restoration the mov.t must be serviced also, which significantly increase cost.
Yes, or can leave embossed for some painting.
Anywhere there is someone is willing to make his printer work for others. They may advertise on online marketplaces, etc. However if there is no ready model, one will have to be adapted or created in CAD. That is the work that takes up more human time and skill, and would cost more.
I do lots of 3D printing.  I don't think you would be happy with the result.  There are higher resolution printers than mine that might be able to pull it off, but I doubt it.
Based on my limited experience, a basic printer should do for making a no pretenses rotating bezel for an economical watch that originally had a plastic one. The top face would have to be sanded, but if it had embossed numbers these could be filled with contrasting paint. The knurled border should be no problem.
Perhaps, but not with embossing and numbers and such.  I have a Lulzbot Mini.  Been printing for about four years.  I love it, but if I ever try to do something small and precise...I am disappointed.  Maybe it is just me.
    • Yes, it looks like GT Revue 30. Doctor, You can not replace escape wheel by the dimensions You listed. One needs to know much more things like number of leaves of the pinion and it's diameter, the position in high of the table and the pinion, the hight between the pivots, the exact pivots diameter... And then, even if suitable wheel is found, one will need to know how to adjust the pallets position correctly. Restoring antique movements is something different than replacing parts. In older movements parts are not interchangeable, this means spare parts do not exist. Here the case is different, but still escapement adjustment will be needed if a wheel from a donor is found. So may be it will be easier to restore the donor for You...Restoring antique movements usually means making of the parts needed and this requires knowlage and working on lathes skill. In this case repivoting of the wheel is the natural solution, but there is a long way that one must walk untill getting ready for such work.
    • I was looking at Essence of Renata, a chemical used a lot for cleaning hairsprings: "Specially prepared solution for degreasing watch and instrument components. Indispensable for degreasing hairsprings." Looking at the MSDS you can see this is just pure n-Heptane, so could be an option for those who don't want to use the chlorocarbons or hexane?     HF6013 - Horological Essence COSHH Safety Data Sheet Horological Essence_0.pdf
    • Welcome from a fellow Seiko enthusiast, there are lots of us on this forum.
    • Nickelsilver is right, movement diameter and keyless works ‘fingerprint’ are important for identifying movements. That said, this appears to be a 7 jewel version of the a Revue 30 movement.  A quick search with google turns up parts movements, and individual parts should be quite easy to come by.  Hope that helps, Mark
