Removing Sicura Screw Back
The main points with the nut & superglue method:
1. It works on any screwback.
2. It works even if it rusted solid.
3. It doesn't mark the back.
4. It comes apart easily.
5. Its cheap.
6. err - that's it.
Nuff said.
Thanks to this forum, I found about this technique.  But initially, I was hesitant to use it.  It sounded crazy!  So I figured posting more cases of its use will give others confidence on the technique.
The watch in this case was from a watchmaker.  He himself wasn't able to open the back case - see all the scratches at the back.
I used a superglue - remover pair from our local hardware store.
It is best to center the nut as precisely as you can to facilitate easier turning.  Otherwise, the pressure exerted on the case back threads won't be even.
The glue remover turns the superglue into gel-like, allowing you to remove the nut after a few hours of applying it.
...and it leaves no mark.  Not that it matters in this case.   :D
  • 4 years later...
On 4/20/2015 at 5:13 PM, noirrac1j said:
NICE!! Congratulations on a job well done!! John that movement looks like a BFG 158 31/7 of which I have many many spare parts of every sort (including balances). You've already mentioned it was a SIC 39? I've never heard of that particular movement in a Sicura, but who knows? It sure does look like a Baumgartner 158 31/7 with 25 jewels which means they've included some jewel caps for the pivots and probably a jeweled rotor bearing for the auto-winder. If I could see the balance I could tell for sure--Does it have a KIF shock system? It is shaped like a little triangle. In any case, If you need any parts, just send me a picture of it and you can have it for free--just pay the shipping. I have entire movements so every little screw, spring, and lever is available!
Still have parts? Struggling to source a spring or two. Thanks!
40 minutes ago, noirrac1j said:
Hello,
Sorry I've been caught up with current events, but yes I have lots of spares. Which springs?
J
I may have found the spring. Do you have any tips on assembling the date/day jumper & corrector works? For the life of me, I cannot figure it out. Separately, do you have any of the Novochoc shock jewel & springs? Missing a spring, and my jewels are pretty beat up...
Yes I have lots of assembly pictures, remind me which BFG 158 31/7 you have? Is it a sicura jump hour or a Cordura day /date?
Joe
Joe
It is a Cordura day/date. That would be a huge help! Also, if you do have any of the jewel/spring assemblies, that would be a godsend. :)
Hello! Sorry for the delay. Please see the attached photos. The white arrows point to the place where the springs contact to keep the date wheel and quick change mechanisms ( the two levers near the 9' hour marker)  in place. I have jewels and springs, so just let me know which ones specifically you need.
Regards,
JSlide1.JPG.9d9d8cbf799a381414905e1376351ba7.JPGSlide2.JPG.a2044f100f319350939cda929a838bdf.JPG
Regards,
You're the man! I cannot thank you enough. Finally got it together. Part of my problem is that I was poising the springs in the top bridge/cover and trying to place over the correctors/jumpers. Finally figured out that the cutaways are for slipping the springs into place.
The jewels and springs are both of the novochoc (triangle) antishock balance jewels and springs (main plate side, balance cock side). See picture.20200409_113525.thumb.jpg.0a031c28691ab3dff501dfac86fdebe9.jpg I don't think my balance staff/pivots have any problems, but if you have a balance complete, I would happily take it and compensate you fully for that. I really appreciate your help and time on this!
    • Well done, let us know how you get on with the citizen.
    • @Neverenoughwatches Rich, I can only agree with you wholeheartedly. I spend a lot of time here learning all sorts and trying to make any little contribution to help others I can. Nothing can last forever and I wish I could do more to contribute to the forum financially and any other support I could.   Tom
    • This forum is a big part of my life. When I retired from horology many years ago due to poor health I missed what I had trained for. On here I can still do my bit in helping and advising others and have a little fun as well.
    • First thing this morning, make coffee, second, check the forum.  I would really miss the forum, not on any social media, not interested in telling the world what I had for breakfast!!! I do consider most of the regulars friends and would wonder what had happened if they stopped posting.
    • Hi all Thought I'd show my small and trying to keep under control watch collection! Apart from the Enicar all were under £12! At least if I destroy them in the process then I won't be too worse off. A few pics to start off with First of all my first attempt. A Thuya pocket watch. It was only running face down and would stop when vertical. So now it still works face down and only slows down when vertical so at least an improvement! 😄  I only have a generic watch oil at the mo so that won't help but I'm hoping to get some more appropriate oils in a couple of months for my birthday. I did have to get a crystal for it since it didn't come with one. It didn't look as though it would friction fit (and I don't have a crystal press in any case) so I glued it to the case with PVA. So far so good. Next up above are a sekonda and citizen automatic. Both non runners. Both with broken balance wheels amongst other things. I'm hopeful the citizen will start when I get the new one I ordered but the sekonda is being kept for spares and trial of new techniques. And finally the Enicar and the timemaster. Both running when I got them. I wanted to get running watches so that at least I stood a fighting chance of still having a running watch after the service! It was all going well on the Enicar until I dropped the balance wheel during reassembly...😔. Unfortunately they are quite expensive to get so for now I'll won't do anything with it but I would like to fix it at one point. The timemaster is still running (yeah!) but I managed to break a dial foot during the deassembly. First repair attempt failed so now I am looking at soldering it back on... So there we go. My initial foray into this great hobby. Thanks for sticking with this tale so far.  I'm hoping that once the balance wheel arrives for the citizen I will be able to say I bought a non runner and fixed it! So fingers crossed. Thanks for looking, Nick
