Removing Sicura Screw Back
The main points with the nut & superglue method:
1. It works on any screwback.
2. It works even if it rusted solid.
3. It doesn't mark the back.
4. It comes apart easily.
5. Its cheap.
6. err - that's it.
Nuff said.
Thanks to this forum, I found about this technique.  But initially, I was hesitant to use it.  It sounded crazy!  So I figured posting more cases of its use will give others confidence on the technique.
The watch in this case was from a watchmaker.  He himself wasn't able to open the back case - see all the scratches at the back.
I used a superglue - remover pair from our local hardware store.
It is best to center the nut as precisely as you can to facilitate easier turning.  Otherwise, the pressure exerted on the case back threads won't be even.
The glue remover turns the superglue into gel-like, allowing you to remove the nut after a few hours of applying it.
...and it leaves no mark.  Not that it matters in this case.   :D
  • 4 years later...
On 4/20/2015 at 5:13 PM, noirrac1j said:
NICE!! Congratulations on a job well done!! John that movement looks like a BFG 158 31/7 of which I have many many spare parts of every sort (including balances). You've already mentioned it was a SIC 39? I've never heard of that particular movement in a Sicura, but who knows? It sure does look like a Baumgartner 158 31/7 with 25 jewels which means they've included some jewel caps for the pivots and probably a jeweled rotor bearing for the auto-winder. If I could see the balance I could tell for sure--Does it have a KIF shock system? It is shaped like a little triangle. In any case, If you need any parts, just send me a picture of it and you can have it for free--just pay the shipping. I have entire movements so every little screw, spring, and lever is available!
Still have parts? Struggling to source a spring or two. Thanks!
40 minutes ago, noirrac1j said:
Hello,
Sorry I've been caught up with current events, but yes I have lots of spares. Which springs?
J
I may have found the spring. Do you have any tips on assembling the date/day jumper & corrector works? For the life of me, I cannot figure it out. Separately, do you have any of the Novochoc shock jewel & springs? Missing a spring, and my jewels are pretty beat up...
Yes I have lots of assembly pictures, remind me which BFG 158 31/7 you have? Is it a sicura jump hour or a Cordura day /date?
Joe
Joe
It is a Cordura day/date. That would be a huge help! Also, if you do have any of the jewel/spring assemblies, that would be a godsend. :)
Hello! Sorry for the delay. Please see the attached photos. The white arrows point to the place where the springs contact to keep the date wheel and quick change mechanisms ( the two levers near the 9' hour marker)  in place. I have jewels and springs, so just let me know which ones specifically you need.
Regards,
JSlide1.JPG.9d9d8cbf799a381414905e1376351ba7.JPGSlide2.JPG.a2044f100f319350939cda929a838bdf.JPG
Regards,
You're the man! I cannot thank you enough. Finally got it together. Part of my problem is that I was poising the springs in the top bridge/cover and trying to place over the correctors/jumpers. Finally figured out that the cutaways are for slipping the springs into place.
The jewels and springs are both of the novochoc (triangle) antishock balance jewels and springs (main plate side, balance cock side). See picture.20200409_113525.thumb.jpg.0a031c28691ab3dff501dfac86fdebe9.jpg I don't think my balance staff/pivots have any problems, but if you have a balance complete, I would happily take it and compensate you fully for that. I really appreciate your help and time on this!
    • people be honest.... Swatch is evil for the watchmakers and repairers, BUT not everything in watches from Switzerland is from the Swatch-Group. As far as i know, Selitta got sacked by Swatch as a Movement-Assembler for them and they started to produce Movements in their own Name with slight Modifications. As far as i know, they sell Parts to the Market for their Movements. In most cases, if a ETA-Movement fails, it is a valid Option to replace it with a Selitta Movement, which i consider the Solution for this Mess with the Swatch-Group...... I have no Connection to anybody at Selitta, but being a Swiss-Guy, i still like to have Swiss-Made Watches, but not from the Swatch-Group.   ok ? regards, Ernst
    • Just one more greedy act by Swatch. They started a number of years ago here in the US..cutting off supplies to watchmakers that could build complications that many Swatch houses couldn't even touch. Old school masters who had gone through some of the most prestigious houses in the world. Otto Frei has some statements on their page about it. I tell all my customers to avoid new Swiss watches like the plague,..unless they just want an older one in their collection that still has some parts out on the market, or they have really deep pockets and don't mind waiting months and paying through the nose to get it back. Plenty of others to choose from..IE Seiko,..or other non-swiss brands Even a number of Chinese brands are catching up with the Swiss,..and I think that in time, their actions will be their downfall
    • Yes. If that's not what you are experiencing...start looking for something rubbing. A 1st guess is that one of the hands is rubbing against the hole in the center of the dial. Especially if you now have lower amplitude in face up/ face down positions.
    • Once a movement has the dial and hands put back and it is recased, would you expect the assembled watch to have the same amplitude as when the movement is in a movement holder and is without hands and dial? Thanks
    • C07641+ not sure what the "+" is for after the last digit.
