Watch repairer recommendations
Ariste Racine started his watch production in 1913 in the Jura mountains north of Geneva. The name "Racine" had already been copyrighted, so Ariste reversed his surname and registered the trademark as "Enicar". The firm produced watches up until 1988. There were massive sales to the Middle and Far East, and you have to watch out for repaints, fakes, etc. This is a nice clean one from the 1960s, with an AR 1010 movement in it.
Edited by WillFly
Another fine watch in remarkable condition with a high quality movement,  well worth keeping and preserving,  I notice it has got Incabloc shock protection.  Incabloc in it's self is fascinating in the way it works and how they ever manufacture such tiny, tiny jewels and settings is a mystery to me.
RogerC
At the moment I have:
15 American mechanical hand-wound pocket watches, of which 11 are Railroad Grade and the rest 3 are US military with a 4th UK military with an American (Elgin) movement.
15 mechanical hand-wound wristwatches: 4 Roamer, 3 Hamiltons (1 with a Swiss ETA 6497 movement), 3 Wittnauer, 1 Enicar, 1 Elgin, 1 Paul Jobin, 1 Longines, 1 Smiths. All pre-1970 with the exception of the Swiss Hamilton.
2 modern quartz watches: 1 Certina DS Podium chronograph and a Seiko Solar.
Edited by WillFly
  • 2 years later...
Hello, everyone,
I have a 'Swiss Emperor' chronograph (Valjoux 72 movement) which needs to be serviced.
I have emailed Mark twice about this, but have had no replies.
Can anyone recommend a reliable place to get the necessary work carried out?
I'm in the Harlow, Essex, area; but posting wouldn't be a problem.
Thanks.
Len.
Hi Folks:
Can anyone recommend a watch repair shop which can reassemble a balance with stud, balance wheel, regulator, stud support and lower and upper indexes for an ETA 6497-1?  The local jewlers I've asked in my area don't want to touch it.  Phone number would be welcomed.
Thanks,
Timezone (Central NJ)
Hi:  Thanks for the encouragement but I don't have the level of expertise required for such a delicate repair.  The hairspring has to be reattached and I assume the balance has to be calibrated which would involve test equipment which I don't have. It was my inexperience that broke it in the first place.  Thanks for your reply.
Timezone
As far as I know ETA does not make a complete balance.  I asked Frei and Esslinger and both said the same.  I've attached a pic of the parts and new balance wheel still in it's sealed package. The bridge is a little blurry. I purchased the balance wheel from Esslinger.
Timezone
    • You don't have to use his special tester. Any good multimeter would work.
    • Yes, it looks like GT Revue 30. Doctor, You can not replace escape wheel by the dimensions You listed. One needs to know much more things like number of leaves of the pinion and it's diameter, the position in high of the table and the pinion, the hight between the pivots, the exact pivots diameter... And then, even if suitable wheel is found, one will need to know how to adjust the pallets position correctly. Restoring antique movements is something different than replacing parts. In older movements parts are not interchangeable, this means spare parts do not exist. Here the case is different, but still escapement adjustment will be needed if a wheel from a donor is found. So may be it will be easier to restore the donor for You...Restoring antique movements usually means making of the parts needed and this requires knowlage and working on lathes skill. In this case repivoting of the wheel is the natural solution, but there is a long way that one must walk untill getting ready for such work.
    • I was looking at Essence of Renata, a chemical used a lot for cleaning hairsprings: "Specially prepared solution for degreasing watch and instrument components. Indispensable for degreasing hairsprings." Looking at the MSDS you can see this is just pure n-Heptane, so could be an option for those who don't want to use the chlorocarbons or hexane?     HF6013 - Horological Essence COSHH Safety Data Sheet Horological Essence_0.pdf
    • Welcome from a fellow Seiko enthusiast, there are lots of us on this forum.
