Roamer Mst372 Movement.
Geo
Yesterday I serviced a vintage Roamer that is fitted with an MST372 movement.
It is really quite a simple movement and comes apart really quickly, but be warned, it doesn't go back so quickly unless you get lucky.  I noticed a lot of little scratches on the train bridge on first inspection, and thought why on earth was it marked so badly................I soon found the reason!  The excessive height of the pinions and layout of the train make locating the pinions a real challenge.  It took me over an hour to get them all locted and running freely.
The marks on the bridge have been caused by years of frustrated watchmakers trying to fit it.  I use pegwood to gently press on bridges and cocks to prevent marking them.  My advice to begginers to this game is, DONT CHOOSE THIS AS YOUR FIRST MOVEMENT, it will put you off for horology life!
For your interest here are a few photos of the watch and the movement.
My Roamer specialist friend, Derek from Southampton, loves doing these movements - but he's been servicing them for years and years!
Ranfft gives the height of the 372 as 4.9mm, which is quite deep for a movement of 25.55mm.
They're lovely movements, though. The  movements after about Cal. 402 (late 1960s) are also good, but not quite as well made, which is why I rarely go for the Searock range and later models.
Hi Will, it certainly is a nice wee movement and is holding very good time indeed. The funny thing was when I first saw it I thought of you. It belongs to a friend who inherited it from his father. The good thing is, he's a painter, so guess what I have him doing in return! :)
I'll hold off on the Roamers then Geo! :)
A thought crossed my mind regarding getting these pinions lined up and steady. Why not use a blob of Rodico to stabilise the wheels in roughly the right place and when you make a little adjustment it'll stay where it's put.
Or maybe I'm teaching my granny to suck eggs! ^_^
I like lateral thinking, I do it myself all the time, but I would bet a large sum of money it wouldn't work. By the way, I hate being negative.
I'm working on an Alpina bumper watch just now, and the train bridge went on in ten seconds flat and that was with four pinions to line up, not just three! It's all down to the far better design.
Would you believe it, the last thing I say to my pal is.............IT'S NOT SHOCK RESISTANT, well you know what's coming next. He had it sitting on top of my stone fireplace, and down it went and broke the balance staff. It lasted all of fifteen hours!
luckily I found a spares or repair runner on Ebay this morning and it does have a shock resist balance, so it will be back to the fiddly pivots again next week. ARRRRRGH!
I have used the rodico trick on a Seiko 6139B for a tricky pinion on the chrono bridge.  The bridge incorporates a spring which makes sitting it down tricky with a wheel that has a long lower pinion shaft, so tends to tip over.  I used very small pieces of rodico to hold th edges of the wheel to the bridge.  Care needed to ensure that all rodico is removed afterwards!
That's it back up and running. I managed to make one good movement out of two, and it now has a Shock Resist balance in it. These pesky opinions that took forever the last time went together in 3 mins flat this time (I timed it). It's currently holding about +4 sec/day.......result! :)
PS it was impossible to use Rodico due to lack of access. What made the difference was the bridge dowels were not so tight!
I just got in after a long days work and thought I'd check out what you guys have been up to and clicked on this thread! Well the other night I was rooting through one of my boxes of bits and remembered seeing this.
So I just dug it out. Balance seems fine its wound up but not running no stem but pretty sure it just needs a good clean and oiling. If you want it Geo pm me your address and i'll post it on to you as i have no use for it.
Hi Maurice.
I think that Geo managed to repair his using parts from another spare movement. (Geo please correct me if I'm wrong here.)
If your MST 372 is still available could you pm me please as I've a supershock with a broken pivot that I'm planning to repair.
Thanks.
Nigel
Welcome to the forum Nigel, I hope you join in with horolological fun here.
You are correct regarding the Roamer, I managed to get another movement with a Shock Resist balance wheel assembly and used the complete movement in the watch after a full service. I did substitute a couple of parts from the original movement to make it perfect.
Maurice, many thanks for your kind offer regarding the MST 372, it really is appreciated. I would indeed have taken you up on your offer, because it would have kept the watch absolutely original spec.
Hello Nigel and a warm welcome, I see you are from the same part of the country as me.
My offer to Geo still stands as since I have been a member I have enjoyed his posts and shared experiences and as a more junior member am duty bound to bestow him with gifts to feed his watchitis. However you may be interested in this.
http://www.ebay.co.uk/itm/MST-10-cal-371-372-shock-resistant-balance-staff-watch-movement-part-/271831156451?pt=LH_DefaultDomain_0&hash=item3f4a6646e3
:thumbsu:
Thanks Maurice.
Haven't the skill and knowledge at the moment to be honest to replace a wheel pivot but certainly something to aim for.
The broken pivot on the watch that I bought is on the wheel that drives the centre second hand. My intention was to find a replacement wheel with a good pivot.
NAD
    • The entry jewel's not as bad but seems still too much lock. I do epilame the escape wheel and pallet jewels, then run dry for about 15 minutes, then put 9415 in exit jewel very little at a time and check with backlight how the oil's distributed.  Another question is about capped escape wheels. Should I somehow wear the epilame off the pivots before installing the wheel? I normally let the escape wheel run dry for that said 15 minutes when there's no cap jewel.
    • Sometimes there's a certain place under the bezel where the case knife is supposed to be placed. In this borrowed pic there's a small crack at 3 o'clock.
    • Hi my fellow forum addicts, I'm writing this as I seem to have a hole in my knowledge (probably one of many!) I seem to have a horrible time removing bezels from watches. I am talking about the rotating type on sports/diving watches. I see many videos where the guy on screen barely inserts the case knife under the bezel and with no effort it pops off easily, then at the end it clicks back into place by hand with no effort. I am sure that part of this is due to skillful video editing, but I seem to wrestle with them, I have tried case knives and  even when using the tool below, I tighten it up in several positions and nothing happens. On a many occasions I have even warped the bezel in my attempts to remove it. Similarly, I have issues replacing bezels after cleaning etc. and often they have to be replaced using a press tool and inevitably are far too tight and will not rotate or loose to the point where they fall off or loose their click (perhaps due to micro warping when I tried to remove??). It is now to the point where I am actually avoiding watches with bezels as my success rate with them is terrible......please help!! In short I am asking: What am I doing wrong? What is the best method for removing bezels - how do you do it? What is the best method for replacing bezels - how do you do it? Any tips or tricks? Thanks
    • Amplitude still seems low, but I'm going to let it run in a bit and revisit. Meanwhile, got the first layer of the calendar works together and made sure the date ring snaps to both in quickset and regular setting. The mechanism is pretty cool, so I took a video.
    • This is the part that need replaced if anyone can point me in the right direction.
